How do you get this Computer to boot from the Sata HDD with out any IDE HDDs?
HP d530 CMT
Re: HP d530 CMT
it is it shows up with the ide hard drives but when i put to sata over ide then it bitchs about it and i cant boot the system jusst says none system disk.My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™
Re: HP d530 CMT
Is the OS on the IDE drive or the SATA drive. If you are booting from the SATA drive the OS has to be on SATA "boot" drive to work. If it isn't on the boot drive then all the PC will see is a empty nonbootable drive at startup."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod Serling
Re: HP d530 CMT
Check BIOS settings.Mann-Made Global Warming.
- Dr Seuss
Re: HP d530 CMT
Originally posted by Junk PartsIs the OS on the IDE drive or the SATA drive. If you are booting from the SATA drive the OS has to be on SATA "boot" drive to work. If it isn't on the boot drive then all the PC will see is a empty nonbootable drive at startup.My Computer.
Re: HP d530 CMT
Re: HP d530 CMT
Well i seem to have found my answer not completely what i was looking for but good nuth,My Computer.
Re: HP d530 CMT
i bet the master boot record is not active on the SATA. try re-installing (a retail xp home cd will work, find a torrent, or use a linux cd) and then try again. the bootloadr is only on one drive based on your symptoms. re-installing should fix it. be sure to unplug the ide drive first.sigpic
(Insert witty quote here)
Re: HP d530 CMT
idk i got it doing what i want it to do so i thinks i am going to let it be for now i dont feel like reinstalling windows again this week.My Computer.
Re: HP d530 CMT
Had to copy some files from the other hard drive like the boot.ini file an ntdlr files then edited the boot file and left it blank so now when i start the system it just says invalid boot ini and boots from the C;/windows and thats what i want it to do in the first place.My Computer.
Re: HP d530 CMT
Ok copied the boot.ini from my computer now it works like i wanted it to.My Computer.
Re: HP d530 CMT
good. that works too.
at least it wasnt like in linux where you could install the boot loader on an olg 6gb drive to allow booting to a non-bootable drive (a raid array on a non-bootable card). in that case, both drives must be present for it to work. but then again, linux has cds that let you re-install the boot loader only.sigpic
Re: HP d530 CMT
Not sure if this relates to your problem, but if there's multiple drives installed then this explains how the letters get handed out:
http://support.microsoft.com/kb/51978
That article was written for MS-DOS, but in my experience it's also correct for Windows, including default letters assigned by WinNt/2k/XP/etc.
Under NT series, it's possible to change the drive letters post-install from within the OS, but that can cause problems with programs that think stuff is installed on a different letter.Last edited by gdement; 09-24-2009, 10:16 PM.
Re: HP d530 CMT
Originally posted by gdementNot sure if this relates to your problem, but if there's multiple drives installed then this explains how the letters get handed out:
i installed Windows xp when the other 2 ide drives were hooked up and i now i have disconnected is that why it could still be showing up as E?My Computer.
Re: HP d530 CMT
Originally posted by ratdude747re-install or ignore it- it will still screw it up. drive letters is a bit dumb when you think of it... unix-like systems dont use them and we dont get this problem...My Computer.
