I love how quiet some of them are but I see at least ten times more of them fail than ball bearings, especially in heat, the sleeve bearing fans just can't handle heat as well. I have a recapped PSU here with a sleeve bearing fan that's going to be running 24/7. It has a Globe Fan sleeve bearing with maybe 2,000 hours on it. I have an NMB here, should I replace it just because it's a sleeve bearing? It is pretty damn quiet though...
Do you replace sleeve bearing fans on site?
Re: Do you replace sleeve bearing fans on site?
Originally posted by Rulycat View PostThere are a lot of cheap sleeve bearing fans with inadequate lubrication (or none at all) straight from the factory. Make sure it's well lubed up. (ooh, matron!)
Whether I replace a sleeve bearing fan or not depends on whether or not it has a good plug to hold the lubricant I use. Some fans just have a small rubber disc which just sits over the bearing housing, and it doesn't provide a very good seal, and oil just leaks straight out. Other fans (like the 10mm thick ones Antec use) have no plug at all. Again, the oil just leaks straight out of those and they fail. If it has a decent plug which seals well, then I just make sure it has enough lubricant.I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by c_hegge View PostOther fans (like the 10mm thick ones Antec use) have no plug at all. Again, the oil just leaks straight out of those and they fail.
The 10mm fans Antec used were Dynatron Top Motor or XFan. It seems to only be the 10mm thick fans that lack the plugs. The rear fans in those are also Dynatron Top Motor, and they have good plugs.
ADDA fans usually do have good plugs, but they fail because ADDA don't give them any oil from the factory. I haven't had any fail if I re-lube them.I love putting bad caps and flat batteries in fire and watching them explode!!
You got lucky then. I often find them with no oil.I love putting bad caps and flat batteries in fire and watching them explode!!
With good shaft scrubbing and proper lubrication, I can restore just about any sleeve bearing fan. Worst I had was a 92mm Mitachi Spacefan. Completely seized and impossible to turn even by hand. Had to hammer the shaft out of the sleeve! After proper cleaning and oiling of the sleeve, it now works great. Granted I haven't used it much at all in a computer, but it still spins freely. I did do 2 other fans that were very seized, though. One of them is a 80mm Supperred that I have now used for a few months in one of my computers and a year or so in another. The other is a 120 mm "Raidmax", also in use for a few month. No problems whatsoever with either.
So no, I don't change sleeve bearing fans... unless the application requires total reliability in a 24/7 environment.
I always took my sleeve-bearing fans apart and lubed them back up with transmission fluid. (I'm sure there were better choices for lubricant, but eh.) Anything from case fans to the tiny ones on old video card processors or chipsets. They always fired right back up, quiet and fast... except for one which must have had a bad component on its tiny PCB.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
Originally posted by Pentium4 View PostWow, that's really cool! I've never done that before, how do you take them apart without destroying them? And do you oil everything except the motor?
Uxwbill has a short 1:45 minute video entitled
Fixing Failed Computer Fans
http://www.youtube.com/watch?v=IeZnHSnxS0I--- begin sig file ---
--- end sig file ---
Sometimes, it's tough to get a fan apart. Often there is a tiny c-clip at the top of the shaft or simply a plastic washer that has a split on one side so it can technically be fiddled out of it's slot. I find myself using sewing needles and other weird stuff to remove these parts at times, but it works. I always clean the shaft and bearing, sometimes running some 2000-grit wet sanding paper through the bearing, very lightly, just to debur anything miniscule. Lube, assemble, GO!Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
