MSI K7N2 Delta 2
  • tazwhippet
    • Mar 2005
    • 3
    MSI K7N2 Delta 2
    I just received a new K7N2 Delta 2 board to replace an Epox 8RDA+ with numerous bad caps. Some posts I've read on this forum worried me that MSI might be using poor quality caps as well. The new board appears to have Rubycon and Nichicon caps. Hopefully this is a good sign.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Find out what series the nichicons are. nichicon has been on a downhill spiral for the last 6 months or so, I've been seeing a lot of bad ones lately.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • tazwhippet
      • Mar 2005
      • 3
      OK Topcat, here's the lowdown on the caps on this board. 6 Rubycon 2200uf 6.3v MBZ, 3 Nichicon 1500uf 16v HM(M), 9 Nichicon 1000uf 6.3v FJZ and 3 green-colored caps marked SE 47 WX 100uf 25v (?). The board is a 6570E Ver. 10.0. I could not find a date on it so I'm not sure when it was manufactured. This is my first MSI board and I probably won't get it installed until this weekend.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the hm series are a new troublemaker.
        got a gallon ice cream bucket here full of bad ones.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          A coffee can full of them here. Dumped a bunch of them last week. Of course, there was a bunch of others mixed in with them
          Team : 49813
          Join in!!
          Team Stats
          • RJARRRPCGP
            • Jul 2004
            • 6301
            But, most of the bad ones appear to be the HM (N), NOT HM (M)!
            Mostly on Pentium 4 motherboards.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
              by momaka
              03-15-2023, 10:17 PM
