Understanding TV Power LEDs
    It seems a lot of people can be confused by the power LED on the TV they're working on. If you've never seen a particular model, the LED may be confusing if it doesn't behave as one might expect. A list of typical power LED states for a variety of brands are included in this post.
    Atec (Only one model for sure)
    Power LED is RED in standby. Powering up the TV makes the LED go ORANGE, then GREEN. If no input present or the signal isn't present, may go orange again. No known blink codes.
    Hyundai (Only one model for sure)
    Power LED is RED in standby. Powering up the TV makes the LED blink GREEN, then go solid green.
    LG (Older models)
    Power LED is RED in standby, then WHITE or GREEN when powered on. May flash when first powering on. Only blink code is continuous flashing on some models, which indicates a power on fault (generally non-specific though typically the PSU.)
    LG (Newer models)
    Power LED is RED in standby, and pulsates red when powering up. Once powered up, the LED goes out or turns BLUE or WHITE. No known blink codes.
    Panasonic (European, possibly other regions)
    Power LED is RED in standby. Immediately detected errors detected lead to a blink code (see service manual.) When powered on, the LED will then blink GREEN. If an error is detected during the power on phase, an error code will then be thrown (LED will blink red.) If the self-test succeeds, the LED will light solid green and the TV should be fully powered up. If a fault occurs during operation, a blink code may be thrown in the same way as before.
    Panasonic (US)
    Power LED is RED in standby. Immediately detected errors detected lead to a blink code (see service manual.) When powered on, the LED will then blink red rapidly. If an error is detected during the power on phase, an error code will then be thrown (LED will blink red.) If the self-test succeeds, the LED will light solid red and the TV should be fully powered up. If a fault occurs during operation, a blink code may be thrown in the same way as before.
    Philips (Some models)
    Power LED is RED in standby. When turned on it may go BLUE or GREEN. If an error occurs, a blink code may be used (this may be green, blue or red.)
    Samsung
    Standby WHITE, RED or BLUE. When turned on, usually blinks. When fully powered up the LED will extinguish. No known blink codes.
    Sharp (non-Vestel) (some models)
    Power LED is RED in standby. When turned on, LED turns green. If an error occurs, the LED will go red and will flash along with the OPC LED. The combined error code greatly narrows down the issue: an error of 2-5, for example, indicates a main board 5V failure. (One can wish for other manufacturers to implement this... but they haven't.)
    Sony
    Power LED is RED in standby. When turned on, may or may not blink. LED turns GREEN when turned on. Blink codes on some models (refer to service manual.)
    Toshiba (non-Vestel)
    Power LED is RED in standby. Powering on may result in a GREEN power LED. If an error occurs, the green will go off. No known blink codes.
    Vestel
    LED is typically lit in standby, and may vary in colour. This varies with each model. When powered on, if a self test fails, the LED will blink continuously until the unit is unplugged. LED is typically dark when powered on. No known blink codes.
    Vizio
    Glowing logo usually ORANGE in standby. When turned on goes WHITE. An error after turning white will typically lead to the LED staying lit white. No known blink codes.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Understanding TV Power LEDs
    Orion (Only one model for sure)
    Power LED is solid RED for off, blinking RED for computer-initiated standby (VGA input). When turned on, power LED turns OFF, and display shows "Please Wait" until startup is complete.
    • Radio Fox
      • Jan 2010
      • 281
      Originally posted by tom66
      ...Hyundai (Only one model for sure)
      Power LED is RED in standby. Powering up the TV makes the LED blink GREEN, then go solid green...
      Now you've confused me.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        We need blinking text. IIRC there is some sort of HTML that does that. Not sure if there is forum code equivlents though.
        sigpic
        (Insert witty quote here)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          His reference is to Hyundai, that should explain it all!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            Lol, yeah. Don't know about their cars but their TVs are sure rubbish. Picked it up (32" LCD) for £10 on eBay, needed a new diode. Also replaced 8 crappy capacitors. Has three dead pixels in a row, solid green ("C" grade panel.) Draws something like 15W in standby with just the LED lit. Put it in the kitchen, not worth selling.
            • Radio Fox
              • Jan 2010
              • 281
              This thread reminds me of a Brain Training game I played on the Nintendo DS where you had to say the colour of the word, not the colour that the word spelled out. It measured the "Stroop Effect".
              http://faculty.washington.edu/chudler/words.html
              • lti
                • May 2011
                • 2557
                The word "green" is colored yellow.
                  That is an error I made, if a moderator wishes to correct it I have no objection.
                  • janet301
                    • Mar 2013
                    • Philippines
                    yeah right..,its colored yellow...
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Fixed it.
                      No sweat. We all mess up from time to time...
                      sigpic
                      • JacobKLl
                        • Oct 2016
                        Oh, my new LG says you thanks! Full information
                        • Raulnn
                          TD Systems K58DLX11US no image no backlight, standby green and red alternating
                          by Raulnn
                          Good afternoon! I have this TV with a Chinese combo plate. The symptom is that you turn it on and the standby LED goes on for a while, alternating red and green. In the end it remains green, but without image and without backlighting. I have measured voltages and they are fine, even the TCON has its correct reference voltages. I think it must be a firmware problem. What do you think?
                          09-28-2023, 10:52 AM
                        • matthewmcconaughey
                          I need help with my friend Sony GDM-FW900 24” CRT
                          by matthewmcconaughey
                          Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                          I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                          1. It started with a bright and greenish picture upon starting a cold monitor.
                          2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                          05-16-2023, 03:15 PM
                        • jimjoe123
                          LCD TV Green/Pink screen problem
                          by jimjoe123
                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                          Then each time...
                          02-23-2020, 01:29 AM
                        • bohaboha
                          Hilti Battery B22 4.0 blink green but not responding
                          by bohaboha
                          The HILTI CPC battery flashes green but no tool starts or works. when testing the battery has 19.2v what could be the problem with them because I have three similar ones but there is nothing written on them all the patches are removed in the first B22 /4.0 with 19.2v the second one B22 /5.2 with 21.8v the third B22 /4.0 with18.3v are all three destroyed ? a bit difficult to believe have also tried other Hilti tools the same thing if someone who can help very grateful...
                          06-03-2024, 08:05 AM
                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-12-2024, 02:00 PM
