New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Re: New Members - please post your introductions here
Hello, I'm Sam and I'm a Tuner-aholic. It's been one day since my latest 'bargain' arrived. I got her following up on a Soundcraftsmen T6002. Hello to All!
Hi, I'm Jasen, from Austin, Texas.
I always liked science and technology, taking things apart as a kid (not good at putting back together then).
Got a degree in Electrical Engineering, then went to the darkside and began programming.
Too many engineers could not use computers...I found a purpose
I already have some experience repairing a LCD Samsung Monitor. The infamous capacitor failure fad. It cost me $300 new, and went bad within 2 years. I was not happy.
But, I managed to find and replace the offending caps. Woo Hoo!
Now I'm on to a repairing a Visio 47 inch LCD TV.
Hope to find success or at least education here!!!
Hi Folks
Chris here in Leeds, UK.
Popping on to the forum to quiz you guys about a repair that I need to do on a Technika Tesco super-crappy-cheap 26" flatscreen TV.
Chris
Howdy. I have had good luck repairing my own electronic devices over the years, mostly by opening them up and looking for the components that are obviously distressed and need replacing. However, I'm a rank amateur with no training in electronics whatsoever, and I am hoping to learn a bit more about what I'm doing by spending some time here.
Hiya, been lurking on this forum for a bit but thought I'd sign in proper. Like most noobs here I am motivated by a powerless Samsung tv. Hope I can fix it soon. This site is a brilliant resource though.
I don't have any technical experience other than building my own pc's and fixing junk when it breaks, but I like tinkering.
Hi there !
I do computer repair for fun and just starting messing around with television repair for the first time thanks to .... well: My Panasonic plasma died! The internet pointed me here - theres clearly a lot of knowledge experience around these parts - I hope to be able to get help
Hi, my name is Ray and I am posting for the first time. I had a problem with a Toshiba 46L5200U LED tv and found a solution here (I hope). The problem was it was flashing the Toshiba logo, then going black. I tried the stated solution and it seems to have worked. (disconnect the DIM #15 wire). I had a question to the gentleman who posted the solution. My question is; Is this a "permanent" solution or should I expect to spring for a motherboard. Also, he said that I could replace the SMD Voltage Regulator, and might like to try that if I could get some guidance. I am not an electronics professional, but am fascinated by electronics and have been tinkering around with it all of my life. I would very much like to tackle replacing the regulator if it is not too daunting. I think the part is like less than $2 but more than .11 cents.
Hi, I'm Fat. I'm a systems engineeer and a wanna be EE. Looking forward to gaining some trouble shooting knowledge from you more experienced people. Thanks for letting me join up!
please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
I've already
flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
please help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
Please help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
