UNI-T UT139B Bad Measurements
  • EJC_LeBron
    • Apr 2025
    • 5
    • Argentina
    Hi people!!
    Since two years I've been working with my UNI-T UT139B multimeter without problems. Since monday, it started to work wrong.
    The first thing I noticed was when I was measuring my house supply voltage (it should be around 220v), but my device showed 190v. Later I've tried to measure a 9v battery and it showed 7.5v.
    I've compared my device with other and I've realized mine was broken. I've opened it, all apears to be in excellent conditions. I've cleaned it but the problem continued.
    Anyone had a similar problem? Anyone have an idea about which could be the problem?
    Thanks in advance!
  • lapot2
    Raccoon
    • Oct 2024
    • 8
    • Россия
    Is the power supply OK? Digital multimeters start to lie when the battery is low. Usually the old ones overestimated the readings, but more modern ones can underestimate them.
    This is worth checking first, including the internal voltage stabilizers.​
    • petehall347
      • Jan 2015
      • 4430
      • United Kingdom
      first try a new battery
      • lapot2
        Raccoon
        • Oct 2024
        • 8
        • Россия
        I screwed calibration in my UNI-T UT139C DMM - Page 1
        Try doing this, and if it doesn't help, check everything else you asked.
        But if you can't or don't understand how to measure all this, buy a new multimeter. It will be easier for everyone.
        The readings changed by 1.2 times in all modes. I suspect that some reference source has drifted away, and with a very small probability that the calibration is damaged. But it is worth trying to calibrate.
        • EJC_LeBron
          • Apr 2025
          • 5
          • Argentina
          I've changed the battery, but it didn't fix the problem. I'm going to check the stabilizers as you said.
          • EJC_LeBron
            • Apr 2025
            • 5
            • Argentina
            I'm cheking that, it seems really interesting. At this time, I have a new multimeter.
            Anyway, I'm going to try fixing this problem just as a personal challenge.
            I will post any bad or positive updates about this.
            • lapot2
              Raccoon
              • Oct 2024
              • 8
              • Россия
              Yes, it will be a useful experience for both you and others.
              • petehall347
                • Jan 2015
                • 4430
                • United Kingdom
                Originally posted by EJC_LeBron
                I've changed the battery, but it didn't fix the problem. .
                now clean the rotary switch .
                • EJC_LeBron
                  • Apr 2025
                  • 5
                  • Argentina
                  That's the only thing I've haven't done yet because it has a certain kind of oil on it, it seems to be something added by manufacturers to facilitate the switch's rotation.
                  And I'm not sure if that "oil" is really necessary or I can clean it with isopropyl alcohol.
                  • petehall347
                    • Jan 2015
                    • 4430
                    • United Kingdom
                    post pictures of it
                    • ngml
                      Repair of an LG split AC system indoor unit PCB
                      by ngml
                      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                      This indicates an error in the communication between the outdoor and the indoor unit.
                      The outdoor unit is fine, so the problem is the indoor PCB.
                      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                      Does anybody have the schematics of this board,...
                      02-01-2025, 12:55 PM
                    • valvashon
                      Repair Success! Middle Atlantic UPS2200R-IP
                      by valvashon
                      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                      02-06-2024, 12:54 PM
                    • DrDos
                      Unit runs but no speaker output kenwood KR-6030
                      by DrDos
                      I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                      09-14-2025, 09:57 PM
                    • nobbnobb1
                      Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                      by nobbnobb1
                      Hi guys,
                      Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                      When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                      02-03-2022, 11:14 AM
                    • Gjackson
                      Air-conditioning unit power supply failing to power up
                      by Gjackson
                      Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                      01-08-2022, 09:24 AM
