TOSHIBA 32" LCD Vertical Lines
  • vikingchow
    • Aug 2010
    • 15
    Any idea about what's going on with this LCD TV? Photo attached.
    How should I determine it's the logic board's problem or the LCD panel?
    Many thanks.
    Viking
  • japlytic
    • Oct 2005
    • 2086
    Re: TOSHIBA 32" LCD Vertical Lines
    It's a bit hard to determine which is at fault, so try carefully removing and reinserting the connectors between the LCD panel and logic boards.
    • PowerAmpFreak
      • 977
      • Sweden
      I once had similair issues with a LCD tv. Problem was a faulty 3,3V regulator on main board. (where all the processors are)
      • vikingchow
        • Aug 2010
        • 15
        There are two ribbon connectors from logic board to the panel, I removed the left one then the left half of panel went black,the other side remained the same picture as before, same thing happen with the right side. Reconnect them, back to what it was. Does this mean the faulty is in logic board?
        • vikingchow
          • Aug 2010
          • 15
          thanks for your advice, I will check the power later.
          • japlytic
            • Oct 2005
            • 2086
            Now that voltage regulators are mentioned, I should add checking the voltage regulators, DC-DC converter outputs and power supply board outputs before removing and reinserting the connectors between the LCD panel and logic board.
            • pauldow
              • Oct 2012
              • 92
              • US
              I know this is an old thread, but maybe this will help someone doing a search.
              I had that problem on a Sony KDL-32XBR4. The problem was a 9.1 K ohm surface mount resistor on the back of the LCD driver board. (T-con). The surface mount components are all capacitors, except for that one resistor. (Maybe there needs to be a badresis.net web site.)
              I don't know if the Toshiba is similar, but it may be worth a look for a cheap fix.
              • Stanley1843
                by Stanley1843
                06-29-2024, 11:54 AM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • oxi1158
                Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                by oxi1158
                My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                10-09-2020, 08:37 PM
                09-06-2024, 05:27 AM
              • gpo23
                Sony KDL-40V3000 - Vertical lines
                by gpo23
                i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                With the new t-con the color are good but there are vertical lines on all the screen :
                I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                Is there a way to fix the vertical lines on the new t-con ?
                Thank you for your help
                gpo23...
                10-04-2023, 09:11 AM
