Samsung 50" Plasma PS50A556S2FXXU
  • AJ11R83
    • Aug 2010
    • 19
    Hi Guys
    I have a problem with my Samsung PS50A556S2FXXU
    I have two horizontal 1.5" black lines runing through the top half of the screen.
    They are not ghost black lines but solid lines.
    Im quite competent in electronics repair, id just like to know if im wasting my time with a faulty display panel before I start fault finding the electronics.
    Hopefully some one can help start me off.
    Cheers
    Alan
  • AJ11R83
    • Aug 2010
    • 19
    Re: Samsung 50" Plasma PS50A556S2FXXU
    Cant seem to edit message, on closer inspection the two lines are half solid half ghosted. Il try to include a picture in a min.
    • AJ11R83
      • Aug 2010
      • 19
      Both lines are solid to a point (see tape marking end of solid line, left to right), the picture isnt too clear, you can see the top line, basically the bottom is the same.
      Any help much appreciated.
      • AJ11R83
        • Aug 2010
        • 19
        Ok so I noticed this too... Ghostly white shape..
        • PlainBill
          • Feb 2009
          • 7034
          If the black line does not run the full length of the panel, it's a defective panel, If it runs the full length of the panel it could be either a defective panel or a bad (open) Y buffer.
          PlainBill
          • cadiman
            • Mar 2010
            • 397
            That bar is a whole buffer dropped out. The upper buffers see alot of heat and so does the y board. I would ohm the buffers then go after the y board. I haven`t seen this on samsung. The one( my first) I just worked on were all caps on all the boards. They had picture issues after warm up or about one Harry Potter movie. Some of the samsungs had heat sinks on the buffer chips and some didn`t. This should be a two part buffer board. The top shouldn`t cost that much. There should be a way to check each input to the buffers to see if you are getting signal to dead buffer.
            Wizard or Plainbill will know.
            v is very high so be careful.
            • AJ11R83
              • Aug 2010
              • 19
              PlainBill
              The black line is pure black to a certain point, then its faded-ghosted like the rest of the way across the screen
              • AJ11R83
                • Aug 2010
                • 19
                What do you mean "ohm the buffers" and go after the y board?
                I can get a y board for £36 to try it i guess http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
                Thanks for the help so far guys
                • AJ11R83
                  • Aug 2010
                  • 19
                  Think i may understand the "ohm the buffers"
                  found this when googling - http://blog.coppelltvrepair.com/2010...er-boards.html
                  • Wizard
                    • Mar 2008
                    • 2296
                    Upper Y-buffer board, replace. If the bars are above the "mid-line", that's upper. If below that, lower buffer.
                    Some panel use one long Y-buffer board.
                    Cheers, Wizard
                    • AJ11R83
                      • Aug 2010
                      • 19
                      Thanks Wizard
                      I take it thats the top left pcb in this picture?
                      • AJ11R83
                        • Aug 2010
                        • 19
                        Well my new pcb arrived quick, and thats made no difference :-(
                        On the Xmain I found this on one of the ribbon cables (in line with my two faulty horizontal lines, looks like a small burn? :
                        Thats on this PCB the other side of the tv, when I pull the top one I lose a small part of the top of the screen, the second one down fills the 2 black lines together. So that sounded normal, untill I pulled the 3rd and nothing, 4th nothing, 5th nothing but 6th I lost the whole bottom half of the screen...
                        Any idea
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          In that last picture, my eye catches the poor soldering on the capacitor above the ribbon cable. May not be important but... what quality.
                          • Wizard
                            • Mar 2008
                            • 2296
                            Now see why I do not like working on plasma TVs on contract and out of warranty since sometimes I must do board swapping to fix the problem. I do not have used parts on hand. I want component level troubleshooting back NOW.
                            Back to yours, either logic board (behind the mainboard, mounted on the panel itself, roughly in center and bit lower). Or mainboard.
                            Cheers, Wizard
                            • AJ11R83
                              • Aug 2010
                              • 19
                              I see, I got loads of service manuals but not one for this tv, It gives me an idea though.
                              All they do is replace y-x-z. So a service engineer has these full set of pcbs(in an ideal world!) and just swaps them out.... job done in 15mins then.
                              I prefer the component level fault finding too, il try with these pcbs doing ohm test comparisons.
                              Wizard what do you think of what looks like a burn on a ribbon cable going into the Xmain pcb?
                              Also I have 6 going into this xmain - what do they actually do?
                              Whats the best way of testing the logic board?
                              • AJ11R83
                                • Aug 2010
                                • 19
                                So New logic board arrived this morning, fitted.... No change :-(
                                Think im going to just stick it on ebay.
                                Thanks for all the help though guys
                                • smason
                                  • 1652
                                  No-one commented on the ribbon cable. Looks like very possibly a problem there.
                                  What does the other side of that cable look like?
                                  • PowerAmpFreak
                                    • 982
                                    • Sweden
                                    But these flatcables has only one pole, right? In the contact there are several pins, don't know why, just to split currents possibly.
                                    I recently changed a Z-SUS on a Hyundai HY4210 (see another thred) and I noticed that both flatcables were solid through, one pole.
                                    So a small damage somewhere would not affect, right?
                                    Any of the experts here has to verify this.
                                    • Dgtech
                                      E. Technician
                                      • Apr 2009
                                      • 1462
                                      • Steeler
                                      it would be nice to see what the other side of this cable looks like. That would tell you how many conductors are in it.
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        In mine, backside was only one pole aswell.
                                          09-07-2024, 05:50 AM
                                        • xNOTx
                                          Verticle lines on Samsung PN42A400 Plasma TV
                                          by xNOTx
                                          Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
                                          [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
                                          04-30-2024, 04:22 PM
                                        • ItalianSat
                                          LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                                          by ItalianSat
                                          Hello Everybody,
                                          I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                                          Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                                          Moreover, I detached the T-CON board for a new round of investigation. I personally...
                                          06-28-2022, 06:02 AM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          Sadly it has vertical lines at the left and one line in the middle-right.
                                          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                          I have factory resetted the TV as well but also with no luck.
                                          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                          A similar issue has been posted as well but also with no actual response ...
                                          Yesterday, 04:19 AM
                                        • afex
                                          Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                          by afex
                                          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                          I have attached an image of the TV with these bars displaying....
                                          11-08-2021, 09:23 PM
