Philips 55PFL6008K/12K Ambilight not working
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    Hey,
    I just got the TV mentioned in the title the other day.
    Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
    It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
    Everything is perfectly fine with it, but the Ambilight just won't do anything.
    At all.
    Won't work on Dynamic, won't work on Static. Not a single sign on life comes out of the LEDs.
    First I checked the SSB for missing components or cold solders, but everything seemed to be fine.
    Then I used the internet, and found a typical problem, where the ambilight fuse will blow, and ambilight won't work at all (like in my case).
    I checked the fuse, but it's fine, and has 12V on both sides.
    After that, I took a look at the connections.
    This is how the ambilight is connected:
    First, from the SSB goes a cable to the WIFI/IR module.
    From that, a cable connects to one of the ambilight sides.
    And from that ambilight side, an identical cable connects to the other side ambilight.
    Between the SSB and Wifi module, the cable is perfect.
    Between the Wifi module and right side ambilight, the cable had a few loose pins, but these are redundant ones, so it even if they were missing, would be still fine. (However, I tried it with an identical cable, and still doesn't work with that one either.)
    Between the 2 sides of ambilight, the cable is perfect.
    What I tried:
    • try cables to rule out cable problems, no success.
    • tried to plug only the other side of the ambilight led strips on, to rule out a bad primary led strip. No progress.
    • measured the voltages on +12V-AMBI and +3V3-AMBI, they are present. (for reference, check the qfu1.2e_la pdf file, page 190)
    My question is:
    What am I missing?
    What could be the problem?
    What exactly control the LEDs?
    Thanks in advance, if you have an idea!
  • William1967
    • Nov 2017
    • 214
    • Netherlands
    Re: Philips 55PFL6008K/12K Ambilight not working
    Try this,
    There are 2 different brands of ICs used to control ambilight:
    1.TI (Texas Instruments)
    2. AMS (austria microsystems)
    There are 2 different upg files for TI or AMS.
    Place these files in the upgrades folder and try which one
    ( Take a thumbdrive and format it 32FAT, than create a folder called UPGRADES.)
    • dominik0801
      • Feb 2018
      • 98
      • Hungary
      Dear William,
      Thank you for your answer.
      The AL strips both have AMS1122 on them, and put the upg file in the folder accordingly.
      Unfortunately that didn't work either.
      I also checked the resistors on the strips themselves, and they have +12V and +3V on them, so supply voltages are not problematic.
      I saw that there are other lines on this cable, which are most likely the control signals, but my knowledge ends there, don't know what and how should be measured.
      I am not certain its not a LED strip problem, but I don't know if both strips would die at the same time.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • double_DD
        Philips curling iron - is this a common AC cable?
        by double_DD
        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
        08-18-2025, 10:04 AM
      • jboxer
        PHILIPS 32PHS5505 side board problem
        by jboxer
        hi, im working on a Philips tv that works good, mainboard good, backlight good but the side board that control the lcd panel don't work good, in first time it only worked when I touched the board in a specific point that was very hot, I think it was a short-circuit and when I touched it my hand worked like dissipator, I had found that the source was a resistance so when I eliminate it there wasn't a short-circuit anymore but still without image only color lines when I touch the new resistance wit a metalic thing and it sparks, where can be the problem? lasts image are a close up of the board(ins't...
        09-02-2023, 02:46 AM
      • kew1701
        Philips taw6205 ambilight speaker STM32 mcu dead
        by kew1701
        Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
        04-09-2025, 03:59 AM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
