UN60D8000YFXZC Samsung - not powering ON
  • MariSico
    • Feb 2018
    • 19
    Re: UN60D8000YFXZC Samsung - not powering ON
    OK, some good news, I hope. I did not have the right SOT-23 3.3V regulators in my stock, but I did have SOT-223 and TO-92. So I used an L78L33 regulator because it was easier to solder, I know it is only 100mA, but so far it worked well. I turned the TV ON for 10 min only, I was afraid that the lower amperage regulator will heat up, but it is not even warm. Do you guys think this will do the job? If 100 mA is too low I could replace it with an AMS1117 3.3 regulator.
    • lotas
      • Jan 2016
      • 4651
      • Russia
      A powerful one is not needed there, since it only powers the micom, so 100mA is enough.
      • MariSico
        • Feb 2018
        • 19
        Thank you very much lotas, and everyone else, for helping me.
          • 12206
          • U.S.
          nice work, you were right on the money about your issue.
          • MariSico
            • Feb 2018
            • 19
            I was lucky too, got also good guidance!
            • Asraf Atb
              by Asraf Atb
              01-27-2025, 05:02 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
