UN60D8000YFXZC Samsung - not powering ON
  • MariSico
    • Feb 2018
    • 19
    Hello all,
    I have this TV for 10 years now, it worked with no issues until a week ago when, after turning it ON, it turned itself OFF, after running for ~10 seconds and it gave me the smell of "electric fire"! I unplugged it from power, removed the back cover and found a "fried" chip, IC1402, on the main board. Removed it from the board, and replaced it with a new one from DigiKey.
    Unplugged all the cables connecting the main board to PSU, powered the TV ON by plugging the cable to the power and measured the voltages on the PSU power connector (backlight also lit up), and all checked out.
    Connected the 28 pins power cable to the main board, plugged the power cable and tried to power it ON with no luck. Unplugging the main board from PSU brings the PSU ON, I can hear the relay clicking also and the backlight also turns ON.
    Did a bit more digging on the main board and found that IC203 seems to be shorted between pins 1 & 3. The markings on it reads GH-J2P (or at least this is what I think), and could not find out any information about it using google. My gut feel tells me that might be a voltage regulator, but I am not 100% sure.
    Anyone has any idea what IC this might be!?
    • 12206
    • U.S.
    Re: UN60D8000YFXZC Samsung - not powering ON
    is IC1402 ok? looks like something is on there.
    • MariSico
      • Feb 2018
      • 19
      That is the original IC1402 that I already replaced, I posted it so people could see how it "exploded"! The second picture is to show the main board code and manufacturing date.
        • 12206
        • U.S.
        • MariSico
          • Feb 2018
          • 19
          Those two caps, C208 and C211, are not shorted, and unfortunately I have no idea what IC 203 is!
          • Diah
            • Feb 2013
            • 6397
            i really appreciate your willingness to do the impossible..
            from the look of the blown Ic and yours MB just Sandwich.. how could you find all under surface are in place !!!... yours case just replace boards from my view.
              • 12206
              • U.S.
              ^^I agree, mainboards are tough to work on.
              • MariSico
                • Feb 2018
                • 19
                Diah, you are right, it could be also a shorted trace in the sandwich, or after replacing this suspected IC, I might find something else broken. In reality it is more a challenge for me to try to fix it, buying a "second hand" board is as risky, most of these boards do not much perfectly, like different code and\or board "topology".
                • Diah
                  • Feb 2013
                  • 6397
                  sami boards if same model dont worry about codes... its native Linux easily can changed to upgrade function or downgrade, just look after model.
                  • MariSico
                    • Feb 2018
                    • 19
                    Here is a close-up picture of IC203.
                    • lotas
                      • Jan 2016
                      • 4656
                      • Russia
                      99% that your micom Weltrend (IC1204) burned out.
                      • lotas
                        • Jan 2016
                        • 4656
                        • Russia
                        IC203 is a 3.3v dc converter that powers the micom, you can unsolder it (IC203) and you will also have a short circuit.
                        • MariSico
                          • Feb 2018
                          • 19
                          Thats why I replaced it.
                          • MariSico
                            • Feb 2018
                            • 19
                            I think I'll unsolder it to see if it is the IC203 that is shorted or the short stays with the board.
                              • 12206
                              • U.S.
                              will replacing IC1204 fix it or does he have to check anything else?
                              • MariSico
                                • Feb 2018
                                • 19
                                Here is an update, I have removed IC203 and the short is in the IC203. I checked the board too, no short in the area where IC203 was soldered. IC1204 is already replaced, so now I have to find a suitable replacement for IC203. Any ideas?
                                  • 12206
                                  • U.S.
                                  post #12 says its a 3.3 dc converter.
                                  • lotas
                                    • Jan 2016
                                    • 4656
                                    • Russia
                                    IC203 (regulator 3.3v) - you can put S-1206B33-M3T1x or UM15333S (see pinout), if you replaced IC1204 (Weltrend WT61P805), then do not forget that it still needs to be programmed using a programmer.
                                    • MariSico
                                      • Feb 2018
                                      • 19
                                      Sorry, I did not replaced IC1204, I replaced IC1402.
                                        • 12206
                                        • U.S.
                                        ok, my question would be is there a way to test IC1204 to make sure its good.
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
