Telefunken 40DTU652 No Sound, no image, no backlight.
  • Raulnn
    • Nov 2022
    • 103
    • España
    Re: Telefunken 40DTU652 No Sound, no image, no backlight.
    ok, well as its not a big screen, I would just take it down to backlights and see if they or their connection/s are the issue, takes some labor but doesn't cost anything but time, just have to treat the panel as if it was a baby so it don't break or crack.
    update!!! I have disassembled the panel, and I have used the multimeter to measure each unit led in the diode scale. they all emit a little light, so they are fine. however, one of them emits that little light when you put the clamps between the negative and the chassis of the tv. I discovered it by chance, the light is dimmer. can it mean that it is communicated? do i do some other test? Thank you
    • Raulnn
      • Nov 2022
      • 103
      • España
      when dismounting i let the receiver go into the frame. I have installed it, I connect the tv without a panel and the leds work perfectly. so I think you have to rule out the leds. I don't know if it could be a short circuit in the panel.
      • Raulnn
        • Nov 2022
        • 103
        • España
        ok, thats good, shows youre getting proper voltage there.
        Sorry if I bother you, it's for discarding the backlight, and to close the tv again and assemble the panel. If with the panel not connected it turns on the backlight, do we rule out the backlight as a failure? despite the fact that with the multimeter in continuity, a small light comes out in a led between the negative of the led and the chassis of the tv. On the other hand, I would doubt the panel. the panel has the tcon integrated. I know the 12v was coming to the fuse. I don't know what tests to do, or if there is something else to doubt. Let's see if someone can help. Thank you very much in advance
        • Raulnn
          • Nov 2022
          • 103
          • España
          the panel suffered damage, so I close the conversation. a fortuitous accident. thanks to all
            • 12104
            • U.S.
            well thats unfortunate but on the bright side, it was only a telefunken.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • B0r1s
              Samsung UE49KS7000SXXH - fast clicking sound in standby mode
              by B0r1s
              PSU - BN44-00878A
              Symptoms:
              The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
              A weak clicking sound was coming from the transformer.
              Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
              Progress:
              After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
              01-17-2023, 04:58 PM
            • Kartowl
              philips 47pfl6158k/12 image faded away, sound still coming from TV
              by Kartowl
              Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
              04-23-2024, 12:57 AM
            • nos_feratu
              Toshiba 49U5863DB Vestel 17MB130S, blank screen, no image, sound ok.
              by nos_feratu
              Hi everybody,
              As per title says, I have an Toshiba D-LED TV set 49U5863DB made on Vestel backbone: 17MB130S motherboard, 17IPS72 power supply and VES490QNDS-2D-U12 chassis which has backlight but no image is displayed. Even so if is hooked up to a input source, sound coming up okay, picture still missing regardless the input source. There is a bit of remote interaction as you can turn on and off but that's pretty much it, there is no control on volume. What I've done so far: because there is no blinking and the TV is booting up fine, I assumed the power supply and mainboard are...
              11-07-2020, 12:06 PM
            • howardc64
              LG 43UK6500AUA no LCD image, backlight and sound okay
              by howardc64
              Similar to another LG UK series here
              https://www.badcaps.net/forum/showthread.php?t=93943
              Have backlight and sound. no LCD image.
              • main board has integrated T-Con
              • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
              • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
              • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
              03-12-2023, 01:04 PM
