Samsung un32j5205af turns on, but needs to have power disconnected to power back on
  • thetonywarren
    • Feb 2013
    • 169
    SAMSUNG UN32J5205AF
    Wierd issue. Set turns on, works as normal, then turn off, and when you try to turn back on, it wont. The backlight comes on, but doesnt boot up. You need to disconnect power supply from back, then reconnect it, and then the set works again. somewhat annoying issue.
    Where to start? I can provide any videos or pictures needed to troubleshoot....
    • 12328
    • U.S.
    Re: Samsung un32j5205af turns on, but needs to have power disconnected to power back
    one easy thing to check is the solder joints on powerboard, look them over closely see if any are bad, examples of bad joints, in case anyone looking on needs it: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4536
      • Italy - Milan
      It seems a software problem, maybe a standby software portion. I see a Winbond flash, you can try rewrite it. Anyway it can be the main software in the emmc flash, mainly that i think..
      • thetonywarren
        • Feb 2013
        • 169
        That's a great idea, I would agree, it doesnt seem like a hardware issue to me, do you have any instruction or help on how to flash/re-write the winbond flash?
        Which IC would need to be re-written?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4536
          • Italy - Milan
          The chip is the one with 8pins labeled Winbond, you need at least a ch431a programmer, maybe with clip, or other more expensive programmers like rt809f, tl866ii+
          • yokoono
            • Apr 2010
            • 514
            Try firmware update:
            https://www.samsung.com/ca/support/m...XZC/#downloads
            • lotas
              • Jan 2016
              • 4850
              • Russia
              Yes, from the beginning you need to do a full reset through the service menu, then try to update via usb to the latest version of "Upgrade File (USB type)
              ver 1150.0 677.85 MB Aug 07. 2019 All OS
              ENGLISH".
                09-07-2024, 05:50 AM
              • Egidio85
                Samsung UE55F8000SZ Turns on and off immediately
                by Egidio85
                good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                This defect happens continuously, hearing the classic click of the relay every time.
                Power supply board BN44-00636B
                disconnecting the mains and lamps from the power board always causes the same problem.
                Is it normal that without anything connected this power supply turns on and off cyclically?
                any suggestions on what to check?
                thanks in advance
                03-11-2025, 12:45 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
