Samsung LN-S4051D no sound
    • 12206
    • U.S.
    Re: Samsung LN-S4051D no sound
    could be a bad cap, check the little ceramic caps for shorts, probe on each end of cap, meter in continuity mode 000 or close is a short, can also use ohm mode, start by checking the ones close to your audio chips, I usually just check them all, doesnt really take much time, helps if you have beep mode on your meter, be sure to check the ones on underside of board as well.
      • 12206
      • U.S.
      some mainboards on ebay for about 40 bux, I think these old samsungs are far more reliable than the newer ones.
      • tmhobadcap
        • Apr 2019
        • 156
        • CANADA
        I have returned the tv to my friend and he gave it to someone. Hope they can fix it.
        Thank you for everybody's comments and suggestions.
          09-07-2024, 05:50 AM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
          09-06-2024, 11:40 PM
