Hitachi 55HR332M12A2 single led for led strip???
  • pr0cess0r
    • Jan 2011
    • 110
    i need to replace those les strip https://www.shopjimmy.com/hitachi-55...trips-4-55r82/
    they are not in stock and other places sell used ones so i would like to find some replacement led.
    my led tester say 2.6v but i assume it is off and those are 3v.
    is there standard led used on those LG bran strip?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: single led for led strip???
    https://www.aliexpress.us/item/32568...d=fnrQFWcFachH
    • pr0cess0r
      • Jan 2011
      • 110
      they are not the same part number are you saying they should work ?
      • nomoresonys
        • 12229
        • U.S.
        its a technique used to find faulty capacitors etc.
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • adelage
          220v Led strip flickering
          by adelage
          Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
          I know that the best solution would be to get a voltage...
          11-03-2024, 09:49 AM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • mikey5791
          Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
          by mikey5791
          Got this working ips led monitor by the brand of
          Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
          Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
          09-04-2023, 03:50 AM
        • wolf1976
          hitachi 50hk5600 problem with display
          by wolf1976
          hi
          i have the above tv and the display starts distorts the display at only in applications like you tube
          after and on the didital channels
          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
          09-13-2025, 02:26 PM
