LG 37LS5600 blows main fuse
  • dimis7
    • Feb 2011
    • 20
    Need some advice to troubleshoot this TV.
    PSU blow the main fuse F100, 3.15A.
    I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
    I checked with DMM for dead sorts but didn't found any.
    Checked bridge rectifier and seems ok.
    Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
    PSU p/n is EAX64405901 (1.6)
    LG p/n is EAY62569601
    Pictures attached.
    Appreciate if anyone can help.
    Thanks.
    • 12221
    • U.S.
    Re: LG 37LS5600 blows main fuse
    if you have not, maybe check, looks like Q601, check that theres no shorts from any leg to the other 2, not a complete test but they usually fail short, I would check all the diodes and resistors too, easier stuff first. all of those will be done with tv UNPLUGGED from power.
      • 12221
      • U.S.
      building one of these for a few bucks will keep from blowing fuses and components up for easier troubleshooting: https://www.youtube.com/watch?v=k5oNQ1etN2c
      • dimis7
        • Feb 2011
        • 20
        Q601 and most, if not all, transistors and diodes are checked and are not shorted. Not checked all resistors yet, its a little bit difficult to read the color code but I will do it.
        I know about the trick with the lamp, maybe I will try to build it if I can find a incandescent lamp
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Check varistor.
          • dimis7
            • Feb 2011
            • 20
            Checked. Its not shorted. Reading 1.2MOhm in circuit.
              • 12221
              • U.S.
              guess that leaves the two 3 pin diodes to check, sticking out of the heatsink there.
              • dimis7
                • Feb 2011
                • 20
                Are you sure? It's between live and neutral. 10 Ohm it's almost short circuit...
                  • 12221
                  • U.S.
                  lol, I got your mov confused with the ntc, your mov looks good.
                    • 12221
                    • U.S.
                    maybe pull up the datasheet on IC501, wonder if its shorted or malfunctioning??
                      • 12221
                      • U.S.
                      then theres the 2 optos, ic502, ic503, what else is left to test?
                      • dimis7
                        • Feb 2011
                        • 20
                        Ic501 is 3BR4765JZ. There is very low resistance between pins 3 and 8 (2.3Ohm). I believe it's ok as per datasheet and created by R510 and R511 resistors.
                        Of course don't know if the chip itself is ok or not...
                        Optocouplers also not shorted.
                        • R_J
                          • 9580
                          Check the resistance between pins 3 and 5 of ic501
                          • dimis7
                            • Feb 2011
                            • 20
                            It's about 3,5MOhm
                            • R_J
                              • 9580
                              That value seems to be ok so the ic "might" be ok. And with nothing else connected, the board should just be in standby. Check D201, D202, what do they read in diode test?
                              • dimis7
                                • Feb 2011
                                • 20
                                Can't find D201 and D202. Maybe you mean D501 and D502 near ic501?
                                If yes they are reading: D501 with positive lead to cathode nothing.
                                With negative lead to cathode: 478
                                D502 with positive lead to cathode nothing.
                                With negative lead to cathode: 479
                                There is also D503 near: with positive lead to cathode nothing
                                With negative lead to cathode 476
                                  • 12221
                                  • U.S.
                                  those two are on the bottom/underside of the board.
                                  • dimis7
                                    • Feb 2011
                                    • 20
                                    Ok found it.
                                    Both measure 200 one way, slowly rising to 1600 from the other way.
                                    • nickgronk
                                      64PN5500 | BN44-00618A Main fuse keeps popping
                                      by nickgronk
                                      Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
                                      I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
                                      The main fuse (T12AH250V) blew
                                      I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped...
                                      01-22-2022, 10:43 PM
                                    • cheeky2
                                      by cheeky2
                                      05-25-2024, 03:27 AM
                                    • socketa
                                      Corsair TX650W fuse, NTC thermistor, and (APFC? Power Transistor) fried
                                      by socketa
                                      I read through this thread, and just want to confirm what i should do.
                                      https://www.badcaps.net/forum/showth...hlight=24N60C3.
                                      This person's fault was exactly the same as mine, even down to the power strip and with the muffled popping sound.
                                      I suspect that my problem started with an old power strip, of which a computer and a 2000W heater were plugged into...
                                      I noticed melting and heat where the heater was plugged in, so i plugged the heater directly into a double wall socket, but still noticed the muffled pop sound when i turned on the computer, and...
                                      07-18-2021, 02:09 AM
                                    • Rictech
                                      Panasonic SA-MAX770PU SMPSU board fault....
                                      by Rictech
                                      Hello everyone. 😀
                                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                      There are no devices that have exploded or otherwise show signs...
                                      08-26-2024, 01:05 AM
                                    • Dani_2024
                                      by Dani_2024
                                      10-28-2024, 05:06 PM
