What I have here is the power supply/Inverter that blew (see pics) . It is out of 26” RCA Lcd model number L26HD31. What do you think happened to cause this?. What parts will I need to fix this ?(should I even bother ? ).
Major Blowup RCA L26HD31
Re: Major Blowup RCA L26HD31
Hi, I just picked up this same model TV. (L26HD31) I took it a part to inspect, but all seems to look clean. Is there some test points that I could check?
I apply power to the TV and it does nothing at all. If I use the remote or press the power button on the TV will also results in nothing happening.
Any help would be appreciated.
@csisatellite I would start with the checking the fuse on the power board and then if that's okay move on to the connector that goes to the main board. There should be a SBY(or similarly labeled aka "stand by"). Better yet, take sharp close-up pics of the power board and upload them here. You should get plenty of help then.
