I have no clue how-to : TV auto-starts with Android no buttons and LED fast flicker
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: I have no clue how-to : TV auto-starts with Android no buttons and LED fast flick
    You master iFix iFix and you will be tv zen master.
    • Ancient1
      • 275
      • Israel
      Davi.p
      I mentioned I worked with SPI , meaning I did something similar ( SPI replaced UART)
      Quite a few versions of UART modules in AliExpress... All very cheap.
      Some with buck conv. 5V to 3V , LEDs to see activity, some within a USB cable ..
      But what worries me is compatibility and drivers.
      Regarding the plan : if Android wants Factory Reset because it can not load, If I set the "Autostart bit" and it shuts down- wouldn't it have the same buttons board driver issue ?
      * I want to buy a programmer that is really useful for many ICs. Comments ?
      • Ancient1
        • 275
        • Israel
        I still haven't found iFix , but did find iFixit https://www.ifixit.com/Device/Television
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4287
          • Italy - Milan
          I think there are too much things that aren't clear for you, here things are getting complex, i don't know if i can follow you sorry..
          for begin this is the channel https://youtube.com/channel/UCzpAcvN9AlDhPu5Kk4iqGbw
          spi have nothing to do with uart, to be safe and sure you can buy a ch341a that is also eprom programmer, start with that, then get another when needs grows up.. next could be rt809f or tl866ii+, bye..
          • Ancient1
            • 275
            • Israel
            Davi.p
            Thanks for the Youtube link !
            Did you mean CH341A like this :
            item 4001145219771 on Aliexpress ( Store : EC Buying )
            OR :
            item 4001347399521 ( "FDKJGECF Module Store" ) which is a programmer that can do it all it seems.
            Sorry if I bother you
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4287
              • Italy - Milan
              #26
              https://r.search.yahoo.com/_ylt=AwrF...2NSy5DM2K9yTo-
              you don't bother me but some arguments are hard to explain also because the language..
              • lotas
                • Jan 2016
                • 4535
                • Russia
                #27
                For UART better on CP2102
                https://aliexpress.ru/item/185910252...00025819000814
                • Ancient1
                  • 275
                  • Israel
                  #28
                  lotas & Davi.p : Thanks
                  I will try and get both, they are cheap and I got 4$ coupon from Aliexp.
                  Have a nice weekend
                  • fixit007
                    Samsung flicker - BN44-00932T board or else?
                    by fixit007
                    I picked up this TV that the prior owner said - just died.
                    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                    05-04-2024, 06:14 PM
                  • Grut
                    JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                    by Grut
                    My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                    Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                    When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                    Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                    11-15-2024, 03:12 AM
                  • howardc64
                    UN65TU7000 strobing / flicker
                    by howardc64
                    Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                    Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                    Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                    03-26-2023, 04:37 PM
                  • jchon
                    How do modern TVs with Android/WebOS/Roku/etc boot? Debug ports?
                    by jchon
                    Hi I'm having issues trying to get my Sony A1E to power on.
                    Which made me wonder, how involved is Android in the booting of the TV?
                    I'm basing this information on what I can glean from the service manual:
                    In my Sony A1E for example I see:
                    BKA which houses the main processor and along with the input/outputs.
                    DKA which possibly does up-conversion, in the block diagram I see VX1 coming in from the BKA and out to the TCON
                    TCON timing board which drives the actual panel.
                    On the BKA there's a sub-system called the U-COM...
                    06-30-2023, 01:58 PM
                  • LEEDASH
                    Aiwa TX-110 Tuner Buttons
                    by LEEDASH
                    Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
                    Thank you
                    05-07-2024, 02:41 PM
