Sharp PN-LE701 turns itself on
  • TVnovice2
    • Feb 2018
    • 11
    I have a PN-LE701 that turns itself back on almost exactly 65 seconds after being turned off. I have done a hard reset, factory reset and updated the firmware by USB, all to no avail. I called Sharp and they said they have experienced this quite a few times and just replaced the main board. Once, a factory reset corrected the problem but only once. Any help appreciated.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp PN-LE701 turns itself on
    Have you taken batteries out of remote?
      • 12307
      • U.S.
      if none of the usual works, look over the solder joints on powerboard very closely, resolder any that look a little suspect being careful not to bridge anything, maybe also suspect the start up capacitors by the connector on powerboard where the cable from powerboard to mainboard is located, example of bad solder joints there in case anyone needs it: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
      • TVnovice2
        • Feb 2018
        • 11
        Yes, I even turned off the TV, unplugged the cable from the buttons and remote and it still turned itself on.
        • TVnovice2
          • Feb 2018
          • 11
          I thought it could be the PS. I had a Vizio that would turn itself off and a new PS solved that but hte the sharp technicians said that only changing the Main board solves the problem- if you have 200 bucks to waste on a main board. Thanks
          • dskall
            • Oct 2016
            • 2905
            • usa
            And you're sure your timer has not been set.
            • lotas
              • Jan 2016
              • 4804
              • Russia
              But if he did a hard reset, reset to factory settings and updated the firmware via USB, then the timer is unlikely to be saved.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Probably. Just throwing things out to try. Seems strange it comes on in the same time each time.
                • TVnovice2
                  • Feb 2018
                  • 11
                  I appreciate any thoughts. Thanks
                    • 12307
                    • U.S.
                    when I have encountered such symptoms, most every time the powerboard was the culprit.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      You might try heating processor and see if anything changes.
                      • TVnovice2
                        • Feb 2018
                        • 11
                        I had it tested in another PN-701 and the same thing happened so its not the PS.
                        • TVnovice2
                          • Feb 2018
                          • 11
                          It's something to do with software, probably a bad NAND chip.
                            • 12307
                            • U.S.
                            well then you solved your own riddle, choices are buy another mainboard, program a new nand chip or buy one already programmed if available.
                            • TVnovice2
                              • Feb 2018
                              • 11
                              Well we got fooled. When the problem first appeared we changed the NAND chip and that did not solve the problem so after much thought and testing we found the "new" NAND was not working and replaced it with another new chip which solved the problem.
                                • 12307
                                • U.S.
                                ok, thanks for the followup.
                                • rayliu11
                                  • May 2017
                                  • 7
                                  How did you replace and program the NAND chip? Did you just solder on a blank NAND chip and flash the firmware?
                                  Thanks!
                                  • sheffieldyorky
                                    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                    by sheffieldyorky
                                    Hey there people
                                    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                    This is what I tried, but not in any order.
                                    Google
                                    YouTube
                                    BIOS
                                    Command Prompt (administrator privileges)
                                    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                    10-25-2025, 02:22 AM
                                  • masterm
                                    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                    by masterm
                                    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                    Problem with TV:
                                    - Netflix stopped working so i tried to do factory reset from the TV menu.
                                    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                    - After waiting for some time, the TV went into a boot loop.
                                    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                    04-30-2024, 03:03 AM
                                  • RRice25541
                                    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                    by RRice25541
                                    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                    the color is all outa wack, like the settings have been corupted,
                                    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                    so
                                    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                    when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                    05-13-2022, 10:44 PM
                                  • mon2
                                    Hisense 55Q9G Android reset / factory firmware reload
                                    by mon2
                                    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
                                    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
                                    01-03-2024, 10:25 AM
                                  • ebj423
                                    asus b75m-plus PSU turns on but no POST. Reset button starts it ?
                                    by ebj423
                                    Posted Today, 07:34 PM
                                    , Hi! In the normal startup process, my pc's power led will turn on, the hdd led will flash brightly for a moment, then beeps once and you would know that everything is starting up fine. But recently, it will just flash dimly(sometimes too dim to see) and then nothing, no beep to show it is posting but the psu is on and all fans/hdds/peripherals/usb are on, even the lan port is flashing. Luckily, I discovered that pressing the reset button after the power button will initiate the post (the hdd led will flash brightly, beeps once and everything starts up fine),...
                                    06-02-2022, 06:05 AM
