Samsung UN60J6200 No power up
  • bradcaps
    • Jan 2019
    • 22
    Re: Samsung UN60J6200 No power up
    It looks like BLU_PWM is .9V, is this correct?
    • dskall
      • Oct 2016
      • 2905
      • usa
      So, I would say you have bad backlights.
      • bradcaps
        • Jan 2019
        • 22
        you maybe right. cant get it into forced backlight mode. Today I suddenly got reading of 100v on center pin of that mosfet and diodes under it. Power cycle, then i get 500mV. On one power cycle it didnt automatically turn on like it has been, i had to use the power button to turn on. this unit is acting erratically.
        • bradcaps
          • Jan 2019
          • 22
          Fired it up on a 100w dim bulb tester, bulb flashes bright then dims every 3 seconds.
            • 12194
            • U.S.
            ok, you see video, and have 388 on filter caps, must be the backlights.
            • bradcaps
              • Jan 2019
              • 22
              Can you post the part number for replacement. Thank you.
                • 12194
                • U.S.
                #27
                  • 12194
                  • U.S.
                  #28
                  some info. from shopjimmy, they're kinda high priced there tho: https://www.shopjimmy.com/bn96-29074...strips-new-12/
                    • 12194
                    • U.S.
                    #29
                    some there, don't recall buying from them so can't actually vouch for them but they have 99% rating and decent price: https://www.ebay.com/itm/20384872651...Cclp%3A2047675
                    • bradcaps
                      • Jan 2019
                      • 22
                      TY, that seller sold 130 units, must be decent quality. Ill give it a try and report back.
                      • bradcaps
                        • Jan 2019
                        • 22
                        Installed new backlight LEDs. With panel disconnected from microcontroller, on dim bulb, the backlight lights up, but only momentarily as it flashes on and off every few seconds. The bulb remains is dim in this case.
                        With panel attached to microcontroller the dim bulb flashes bright after the flash of the backlight. I do see blue LEDs light up on the TCON board now but only momentary before backlight flashes off.
                          • 12194
                          • U.S.
                          #32
                          ok, so if dim bulb tester doesn't stay bright thats good, I would try it without the dbt.
                          • bradcaps
                            • Jan 2019
                            • 22
                            Ok the backlight is working. But I maybe messed something up. I did accidentally make small crack in a corner Chalk it up as a learning experience.
                              • 12194
                              • U.S.
                              #34
                              Damn, sorry to hear that, they are easy to break.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • nathan425
                                Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                                by nathan425
                                Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                                Symptoms:
                                • - no power
                                • - no standby LED
                                What I've done so far:
                                - confirmed power supply is OK
                                -- CN201 #4 showing 5.3V
                                -- BD207 showing 5.3V
                                -- removing the cable between the main board and the power board turns on the backlight.
                                Pushing the power button on results in no change to any of the pins connecting the two boards.
                                - function assembly appears to be NO GOOD
                                -- there is no voltage showing on any of...
                                11-01-2023, 06:34 PM
                              • mrtek
                                Samsung UN43NU6950FXZA No power
                                by mrtek
                                Hi
                                Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                Main fuse = OK
                                Back light LED = OK. Power them with aux power source
                                LED output = OK 156V
                                I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                07-20-2025, 08:06 PM
