Panasonic TX49DX650B no picture
  • CoolJc
    • Feb 2022
    • 18
    • uk
    Panasonic TX49DX650B - intermittent have sound & backlights but no picture, got LT feed to T-con fuse, tried a T-con board from Ebay but got permanent no picture with that so it got sent back,
    Guessing it must be a T-con or Main board problem - anyone experienced (and cured) the same fault?
  • CoolJc
    • Feb 2022
    • 18
    • uk
    Re: Panasonic TX49DX650B no picture
    Further info re intermittent no pic,
    If i disconnect the right ribbon connector, the right side of the screen goes white, If i disconnect the left, the left side goes white
    When both ribbons are connected the screen is dark but strangely there is a 'glow' across the bottom edge stretching up a few inches
    Q - if there was a minor error with the led strips could the main board sense a problem and blank off the video info?
    Reminder - When not blanked off, the picture is great
    Tis a strange one
    • Fly_Among_Stars
      VIZIO E70-E3 Half picture with half TCON
      by Fly_Among_Stars
      I have a VIZIO E70-E3.
      Symptoms: Black screen, no picture, but LED backlights are working.
      I probed the power board and voltages are as listed on the board.
      Main board appears fine, too.
      I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
      There are two separate ribbon cables feeding the LCD.
      If both are connected, the screen is black.
      If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
      04-24-2023, 08:20 PM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • FZG
      Panasonic AG-1000B VHS player with bad picture quality
      by FZG
      Hello!
      I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
      Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
      I want to know, is this something that could be solved by recapping or is the video head likely gone?
      Also, what mechanism is this?
      Any feedback is appreciated!...
      05-06-2024, 07:16 AM
    • Bazfletch3
      Panasonic TH-65FX800A backlight LED's working but picture is very dark
      by Bazfletch3
      Hi all
      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
      From there I envisaged that the backlighting wasn't working, however...
      01-08-2024, 10:18 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
