Problem with pfc in lg 42lm620S
  • raydem
    • Dec 2012
    • 27
    • spain
    I have a problem with the power supply of LG 42LM620S, the power board is EAX64427101. The problem is the pfc circuit, when I connect it the board has a short circuit, but If I remove L601 the board works fine without leds light. Also, if i disconnect the F101 the board is in short circuit but the pfc circuit works fine, 380V. i changed the fan7930, the mosfets q101, q102, q602 and q601. Also i changed IC101 ( L6599). To eliminate circuits I removed d254, d260, d253,d261, d251 and q251.
    I have not idea what more check..
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Problem with pfc in lg 42lm620S
    Did you check Q603 and Q604 and all the gate resistors and diodes?
    • raydem
      • Dec 2012
      • 27
      • spain
      Yes, all it is ok.
      • raydem
        • Dec 2012
        • 27
        • spain
        Any idea??
        • kasfamily
          • Aug 2014
          • 765
          • Russia
          D603-?
          • raydem
            • Dec 2012
            • 27
            • spain
            D603 is ok.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • dicky96
              Thermal Circuit Breaker Problem - can we fix it?
              by dicky96
              Hi guys
              I have this ETA 3120-F321-P7T1-R14XB3 Circuit breaker from a Hill DX3000 Power Amplifier.
              The first problem I found with the amp was a faulty 25A Bridge rectifier FB2506 that was short circuit on one leg AC to negative
              I've replaced that but the amp has no power. That is because the ETA circuit breaker is open circuit on one pole. The other pole switches OK. The primary of the transformer seems OK (not short or open and doesn't look distressed) so I think that ETA circuit breaker is the only other problem I need to fix.
              Problem is finding...
              03-08-2019, 06:45 AM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
