Samsung TV UN65MU8000 FXZA Not Working
  • bmontou
    • Aug 2022
    • 10
    We had a power outage and the tv was dead when the power came back to the house.
    When plugged in my tv had no stand by light and the led’s did not come on.
    Here's what I've looked at:
    Unplugged main board from power supply - Backlights come on and do not blink.
    I changed the main board and now the led’s blink on and off, but show no picture. When the ribbons that go into the main board are detached the tv will blink 1 time and then go to a solid dim light on the screen with no picture. The company who sold me the main board is saying that the main board is good and and panel must be out. Please advise
    MAIN BOARD = BN94-12295K
    • 12274
    • U.S.
    Re: Samsung TV UN65MU8000 FXZA Not Working
    may have gotten a mismatch, see if the numbers on the white stickers match.
    • bmontou
      • Aug 2022
      • 10
      They match
      • lotas
        • Jan 2016
        • 4749
        • Russia
        When plugged in my tv had no stand by light and the led's did not come on.
        I changed the main board and now the led's blink on and off, but show no picture. When the ribbons that go into the main board are detached the tv will blink 1 time and then go to a solid dim light on the screen with no picture. The company who sold me the main board is saying that the main board is good and and panel must be out. Please advise
        Let's try to restore your original motherboard, do you have a programmer?
        • bmontou
          • Aug 2022
          • 10
          No.. Basically I’m asking if by what I’ve described does it sound like the main board or the panel. He insisted that the main board he sent works and that it must be the panel, but I dont know if he is just saying that because I paid for it. It went from doing nothing to changing the main board and now the standby light blinks on and off and the LED’s blink on and off when everything is connected and a solid dim light when the ribbions are disconnected
          • lotas
            • Jan 2016
            • 4749
            • Russia
            Basically, in the "MU" series, when the power is turned off, the standby firmware flies, but the panel cannot be damaged. Try to answer in turn first one white loop and turn on the TV and see what happens, then insert the first one back and turn off the second loop.
            • lotas
              • Jan 2016
              • 4749
              • Russia
              The seller can say whatever he wants, just to sell, and that the mainboard was working.
              • bmontou
                • Aug 2022
                • 10
                I also tried that both with the same result as when both ribbons were disconnected. It blinks once and then the screen goes to a dim light that stays on, but doesn’t blink.
                • bmontou
                  • Aug 2022
                  • 10
                  Could the ribbons be damaged?
                  • lotas
                    • Jan 2016
                    • 4749
                    • Russia
                    Does the number BN97-xxxxxx match on the white nameplate?
                    • bmontou
                      • Aug 2022
                      • 10
                      Yea and it the same.
                      • lotas
                        • Jan 2016
                        • 4749
                        • Russia
                        It's strange, the two halves of the panel can't go bad right away, it's just that T-CON is built into the motherboard, if it doesn't work, then there may be such a reason, try returning this motherboard and buying it elsewhere.
                        • bmontou
                          • Aug 2022
                          • 10
                          I just wanted to make sure the main board is the problem before I purchased another one.
                          • lotas
                            • Jan 2016
                            • 4749
                            • Russia
                            But without a knowingly 100% working motherboard, you can’t check it.
                            • lotas
                              • Jan 2016
                              • 4749
                              • Russia
                              Look in the advertisements for who sells such a TV with a broken screen for spare parts.
                              If you had a programmer, you could try to restore your motherboard.
                                • 12274
                                • U.S.
                                +10, probably bad board.
                                  • 12274
                                  • U.S.
                                  look it over closely, can check each pin for continuity with multimeter.
                                  • lotas
                                    • Jan 2016
                                    • 4749
                                    • Russia
                                    LVDS cables themselves cannot deteriorate, unless they are correctly inserted into the connector and the contacts are not damaged.
                                    • bmontou
                                      • Aug 2022
                                      • 10
                                      It it very difficult to find this main board from a reputable company.
                                        • 12274
                                        • U.S.
                                        this one might not match, don't know but its not a bad price, maybe email shopjimmy give them the details, they might have a match: https://www.shopjimmy.com/samsung-un...-1576267696779
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
