Samsung UE55MU6105K black screen
  • totof
    • Feb 2017
    • 160
    • france
    I have my UE55MU6105K TV model that I am trying to repair.
    BN41-02568A / BN94-12195C motherboard.
    If I disconnect the motherboard from the power board the backlight works.
    When the motherboard is connected the backlight works but the screen remains black. The standby LED is on when the 220V is connected, but it goes off after about ten seconds. The TV consumes about 22W, impossible to put the TV on standby mode with the remote control. The main processor gets very hot.
    I bought another second-hand motherboard of the same reference (BN41-02568A / BN94-12195C) and with this card nothing happens, the TV does not start and the standby LED is off. The seller told me that his card worked but I have a doubt.
    With my CH341A programmer I copied the contents of IC1604 W25Q40CL from my motherboard to the one I bought and the result is that the standby LED is on but the screen remains black and the TV consumes about 20W. Unable to put the TV on standby mode with the remote control.
    I did the reverse test by copying the contents of IC1604 from the motherboard I purchased to mine and the result is that the standby LED stays off and cannot start the TV. I see a consumption of 2W (the main processor heats up a little).
    Attached is the IC1604 dump of both boards, is it possible for someone to check them if possible ?
    Thanks in advance for your help.
  • totof
    • Feb 2017
    • 160
    • france
    Re: Samsung UE55MU6105K black screen
    Hello.
    Can anyone tell me how I can repair my TV?
    In the binary that I extracted from IC1604 I see that all bytes up to address 1000h are at FF, is this normal?
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Chrissygizmo
      samsung galaxy ao2s very temperamental after screen replaced
      by Chrissygizmo
      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
      Ive eventually managed to get it on and working but it's very temperamental...
      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
      05-26-2024, 12:05 AM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
