Samsung UE37D5520 boot loop partly fixed
  • notallbad
    • Oct 2012
    • 1190
    So the tv is a Samsung Ue37D5520, found a UE40D5520 tv with what I believe to have a faulty panel so out comes the main board to donor into the 37".
    Board connected and tv powers on and appears to stay on but what should I do before doing any reset, fw update, connect to a network or use apps etc...???
    Also should the usb update file be for the UE37 or UE40???
    thanks
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UE37D5520 boot loop partly fixed
    think the firmware will be the same for both.
    • notallbad
      • Oct 2012
      • 1190
      yh think your right, filenames the same and file size the same.
      So should I do a factory reset first in service menu then with the tv on insert usb stick with Samsung website Update file?
      What step is needed next?
      Guy on ebay who does programmed nand chips recommends doing a software reset/software upgrade, and Smart upgrade procedure after installing his chip.
      What is the smart upgrade? anyone
      • nomoresonys
        • 12331
        • U.S.
        ok, now I read it right, go ahead and try it see how it acts, last sammy I did with a slightly different board worked straight away, didn't need to reset or update.
        • notallbad
          • Oct 2012
          • 1190
          Well the factory reset and update to 1025 went ok but before this the Smarthub function just says network not currently connected though have tried a lan cable and a samsung wifi dongle that does connect to router but still no smarthub function on tv?
          Have checked date/time settings, switching between auto and manual but still no dice!
          • nomoresonys
            • 12331
            • U.S.
            I'm not exactly sure but none of the tv makers are too swift with keeping the apps and stuff updated and functioning as the tvs get older, they may have abandoned it.
            • nomoresonys
              • 12331
              • U.S.
              I have evn seen where an update will break a function that previously worked and I'm pretty sure they do it on purpose, why? I don't know.
              • nomoresonys
                • 12331
                • U.S.
                maybe make sure ALLSHARE is on.
                • nomoresonys
                  • 12331
                  • U.S.
                  ❑ ❑ Setting❑the❑Network❑
                  Network❑Settings❑
                  O
                  MENUm❑→❑Network❑→
                  Set the network connection to use AllShare™ and perform software upgrade.
                  Network❑Status
                  O
                  MENUm❑→❑Network❑→
                  You can check the current network and Internet status.
                  AllShare❑Settings
                  MENUm❑→❑Network❑→
                  O
                  Selects whether to use the call arrivals text message contents, and schedules
                  set on the network. For details on set up options, refer to the "AllShare™"
                  instructions.
                  For LCD 550 series and above
                  Network❑Settings
                  → ENTERE
                  Network❑Status
                  AllShare❑Settings
                  English
                  → ENTER
                  • nomoresonys
                    • 12331
                    • U.S.
                    you probably already have this, some downloads there: https://www.samsung.com/uk/support/m...E37D5520RKXXU/
                    • notallbad
                      • Oct 2012
                      • 1190
                      Not exactly sure, but after doing the update to 1025 I went via main menu, Support, Smart Hub and it said 'Installing' then 'Starting' and up came smarthub and working now.
                      Sure enough smarthub updated from ver 3.288-6.0.00067 to ver 3.7451-6.0.00067
                      Before the update when I went through the menu to smarthub it just said 'starting' so possibly this step needs to take place after the update. Possibly???
                      Its also on its own done a service update on bbciplayer, bbcnews, muzu.tv.
                      Shall proceed with 1027 update though doubt theres much more benefit to be had.
                      • nomoresonys
                        • 12331
                        • U.S.
                        Cool, glad to hear it
                        • notallbad
                          • Oct 2012
                          • 1190
                          Went ahead and did the 1027 usb update all ok.
                          Although smarthub starts no apps still, bummer.
                          Anyway, i did the plug and play option in menu (1st time installation) and in the process i decided to check for updates (skipped this step previously) and it found a 1027 update, well, I thought I had just done that, so it did it anyway but to no benefit still.
                          Beginning to think corrupt nand.
                          • nomoresonys
                            • 12331
                            • U.S.
                            Saw this, don't know if it is just that app or what but I didn't see your model on the list so it might not even be relevant: https://www.samsung.com/uk/support/t...012-smart-tvs/
                            • nomoresonys
                              • 12331
                              • U.S.
                              a few things to try: https://kcscfm.com/samsung-tv-apps-not-working/
                              • nomoresonys
                                • 12331
                                • U.S.
                                1 Press the Smart Hub button.
                                2 Select Featured. ...
                                3 Navigate to an App that needs updating, then press and hold the Enter button until a sub menu appears.
                                4 Select Update apps.
                                5 Click Select All.
                                6 Select Update.
                                Any apps with an available update will begin updating.
                                • Takeatry
                                  Yet another Samsung QLED Boot Loop
                                  by Takeatry
                                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                  10-04-2024, 02:57 PM
                                  09-07-2024, 05:50 AM
                                • Nicktronic
                                  Samsung QN75Q60TAF Boot Loop fixed but no picture
                                  by Nicktronic
                                  Hey, I have this Samsung TV that originally had a boot loop problem. I've isolated the pins on the ribbon cable to the panel board to stop the looping. I can hear the music on startup and when I move through menus with the remote, but there is no picture. I'm wondering what pins/signals I should look for that enables the Main Board to provide the video? Is it possible the main board is damaged? Anybody have experience wtih this type of issue?
                                  Thanks!
                                  04-10-2023, 07:06 PM
                                • howardc64
                                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                  by howardc64
                                  TV was fixed just after removing Samsung's rear snap cover.
                                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                  Maybe PSU->backlight connector didn't have a good contact?...
                                  07-23-2025, 12:34 AM
                                • eigma
                                  Samsung UN40H5003 boot loop every ~8 seconds
                                  by eigma
                                  Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                  Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                  SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                  Main board: BN94-07592P / BN97-08922R...
                                  11-20-2024, 10:31 PM
