Samsung UN65HU7250 Power Supply Repair
  • mmartell
    • Oct 2013
    • 3189
    The supply is a BN44-00782A.
    Was told there was a "popping noise" and the set went dead. Upon inspection there was a split ceramic cap C814, a failed mosfet, either Q801 or Q802 I pulled and am replacing as a pair and of course the main fuse.
    I replaced the cap marked 221 1kv with a 221 2kv (which I think will be fine?) and will be getting the other parts today. The switching diodes at D801 and D802 look and test good but the ferrite beads at BB801 and BB802 appear to have taken much current and are discoloured though still test as a short.
    Do the properties of these beads change with heat/overcurrent such that they've become discoloured or are they fine ? I have no schematic and no way to measure them so can't replace with like for like.
    (pic in next post)
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung UN65HU7250 Power Supply Repair
    And here is a pic of the beads in question.
    • dskall
      • Oct 2016
      • 2905
      • usa
      As long as thier intact and have continuity they should be fine. They are just compressed ferrite
      • mmartell
        • Oct 2013
        • 3189
        Very good thanks for that.
        • mmartell
          • Oct 2013
          • 3189
          Power supply is reinstalled and tv is working. Thanks for the input.
            09-07-2024, 05:50 AM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • alltvrepairs
            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
            by alltvrepairs
            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
            Any one met this problem in the past?...
            10-08-2025, 07:34 AM
