Re: SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
Here's some pics
If voltage is with respect to the source pins, the difference there is only .1 volt so I guess that would be -.1v at the gate?Leave a comment:
Hmm according to the datasheet if I'm reading it right, a typical threshold voltage at the gate would be -1.7v so a much higher voltage which +12.8v definitely is would keep the transistor from switching on, thus no voltage seen at the drain. Am I correct in my thinking?Leave a comment:
Can we get some good picture of panel boards??Leave a comment:
I get 150k resistance between the source and gate so it's not like the gate is getting the 12.8v from an internal short...but I'm having trouble seeing where it comes from. Trouble tracing these tiny capacitors and resistors. Is there any chance I'd be able to find a schematic ?Leave a comment:
Hmm according to the datasheet if I'm reading it right, a typical threshold voltage at the gate would be -1.7v so a much higher voltage which +12.8v definitely is would keep the transistor from switching on, thus no voltage seen at the drain. Am I correct in my thinking?Attached FilesLeave a comment:
I did some more poking around and discovered that 12v goes into the IC marked G4435SS but doesn't come out the other side. I see 12.9v on pin 1,2,3 and 12.8 on pin 4 which I can't quite figure out how it's getting that. That pin 4 has high resistance between it and 1,2,3 and looks separate like it's the gate or something. Datasheet time.Leave a comment:
Clearly tho, the mainboard not producing the 12v to run the panel is the major problem I need to solve first. The client probably prefers to spend the 45$ for a new mainboard and skip the time it will take to chase this one down. He would give me the old dead mainboard but it would probably be hard to repair without the matching power supply...Leave a comment:
This is the newest tv I've been called to work on. Made in 2020. Shame on samsung. I see evidence of the challeges to come for us as they keep cutting costs and making things easier to break and harder to fix. The back of this TV had no screws which might be nice if it wasn't such a pain to separate all the clips. Ends up being more work in the long run. The tcon built into the main, I have never liked, but only one cable to the panel and daisy chaining the panel boards makes it so u can't easily test left and right of the panel by disconnecting a cable. You can only easily test the first board. Oh and the power supply being directly connected to the back lights with no wires is probably another issue that could make diagnosis harder in some cases. Whew!Leave a comment:
do you have a steady backlight with cable from powerboard to mainboard unhooked? what is the discoloration on the pins on picture 6?Leave a comment:
Not sure the t-con is on the panel. Probably a short on board or panel causing reboot.Leave a comment:
TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
tcon is built into mainboard.
Only one cable goes to panel boards.
there is a cable from one panel board to the other that links them.
cost cutting measure that results in us having harder time to diagnose.
removing the link to the second panel board allows TV to stay on with stable backlight but no image.
used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board. maybe pin 11 or 12. that causes TV to come on and remain stable but still no image. TV has some voice feature that talks and says something about setting up the tv.
checking panel boards I see no 12v coming in.
checking on the mainboard I see no 12v on the caps close to the lvds cable or on the coils around there, or on the voltage regulator.
seeming like it must be a main board problem but do I also have a panel problem since I was able to use cut off tape method to gain stability? Why does having the second panel board plugged in make it reboot? if there's no 12v going to the panel boards anyway, why should masking a pin do anything at all to change operation?
there is no 12v but the tiny voltages that carry the picture information are there and I assume the clock lines too. some error there maybe tells the main board to shut down?
This is the newest tv I've been called to work on. Made in 2020. Shame on samsung. I see evidence of the challeges to come for us as they keep cutting costs and making things easier to break and harder to fix. The back of this TV had no screws which might be nice if it wasn't such a pain to separate all the clips. Ends up being more work in the long run. The tcon built into the main, I have never liked, but only one cable to the panel and daisy chaining the panel boards makes it so u can't easily test left and right of the panel by disconnecting a cable. You can only easily test the first board. Oh and the power supply being directly connected to the back lights with no wires is probably another issue that could make diagnosis harder in some cases. Whew!Last edited by triplefour; 07-28-2022, 08:05 PM.Tags: None
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by NWArkGuyWell, I will be the first to admit that I screwed up...
In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
I have 2 that I have found and have in my possession. ... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by YanlebHi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
If they are not compatible why did Samsung give them the same part number to begin with?08-04-2025, 11:35 PM -
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
- Loading...
