Help!
  • mpobanion
    • 23
    Help!
    I replaced two 1000uF 200volt Capacitors that were below the +130 supply. The voltage drop across the Cap's + to - is about 163volts but the measurement from a ground point to + side of Cap's is only 116v. I ‘am learning about this all and not an expert.
    Does anyone know, if there is no High Voltage going to Cathode Ray Tube's in a rear Projection TV's, would the LOFT or fly back transformer be at fault always and could bad convergence Integrated Circuit's stop any picture HV from getting to CRT's?
    PlainBill, could you possibly help since you have knowledge about TV's
  • PlainBill
    • Feb 2009
    • 7034
    Re: Help!
    163 volts is about what I would expect from a bridge rectifier with 120VAC input. The discrepancy between the voltage across the caps and the voltage to ground is most likely because you have a live ground at this point in the circuit. It's been a long time since I worked on a rear projection TV, but IIRC, CRT designs have used a SMPS to produce the desired voltages. I see no reason why a RPTV wouldn't do the same.
    As far as the convergence ICs preventing high voltage from getting to the CRTs; I would say that is highly unlikely. A fault in the convergence circuit MIGHT cause shutdown of the deflection, but I would look to other things first.
    As always, a good (or even poor) schematic, or even a model number would help immensely. And many people here have a much greater knowledge of TVs. At this point in my life it would take a great deal of coercion before I would stoop (physically) to working on one. Well, maybe if a very beautiful woman asked....
    PlainBill
    • nassih
      Philips video projection picopix bios
      by nassih
      hi community i have a Philips video projection picopix with blue screen probleme,i need someone for editing bios file,i have the dump...
      10-12-2021, 02:37 PM
    • itelite
      Any source for ws-65905 projection tv parts?
      by itelite
      Working on a Mitsubishi ws-65905 with all kinds of problems. Convergence is off screen geometry is off, who knows what else.
      replaced convergence ICs to no avail. Was hoping to just purchase either a power supply or all internal boards and call it a day. To my surprise i cannot find any such things online.
      I would have thought since you cant give these things away someone would be breaking them down for parts.
      If anyone has a source, or a ws-65905 collecting dust in their shop let me know please
      10-10-2019, 10:52 AM
    • rattlesnake
      Samsung SyncMaster 955DF dim image fix
      by rattlesnake
      This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
      To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
      08-12-2023, 07:03 PM
    • PTKmoron
      RCA P52937 (PTK195) unusual convergence issue
      by PTKmoron
      I have a strange convergence issue with my old 2002 RCA big screen, Does anybody out there who tinkers with the older CRT big screens have any info on the convergence power supply board (number POWR-530), or the Digital Convergence Main Board (either DIGI-970 or DIGI-980) for a 2002 RCA p52937 with chassis PTK195M4B?
      I know about the convergence power supply board usually going first, but the thing is, I have the advance convergence menu still, and its only the left side of the picture thats bowed/off slightly. Its adjustable to perfection on the entire screen, even where its bowed...
      10-07-2013, 04:08 AM
    • navagator
      Hitachi Power Supply Unit Interchangeability
      by navagator
      I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
      Does anyone know if these 2 power supply boards are interchangeable?
      Thanks.
      01-08-2024, 07:53 PM
