samsung un65nu6900f common problem, digging deeper
  • Cornito
    • Jan 2024
    • 90
    • France
    #101
    I'll do the same, but now I may have a chance to keep it alive for some times.
    I've redone all solders with better tin, smaller wires and I've added the dcdc step up.
    It works, this has a bit corrected the red color. But now I have a small black line at the middle of the screen some times.
    Please find attached the pictures of the job and a short video where we can see line appearing .
    • Cornito
      • Jan 2024
      • 90
      • France
      #102
      I've corrected my line that appeared some times by increasing a bit the VGH voltage, from 18.3 to 19V.
      still having a red color issue on one side, red is more pink than red.
      • lotas
        • Jan 2016
        • 4554
        • Russia
        #103
        You won’t be able to do it perfectly, since the CKVs on the non-working side don’t work, try restoring them, maybe the problem was only in the VGH.
        • Cornito
          • Jan 2024
          • 90
          • France
          #104
          I've reduced the VGH voltage, to protect the panel only, the issue was on CKV.
          The only thing that I could do I to check which one is the defective one. And rebuilding the others may help.
          But I'm not sure that this will help the panel to stay alive for long time
          • lotas
            • Jan 2016
            • 4554
            • Russia
            #105
            Well, at least that's what it's like. You can also try...
            • Cornito
              • Jan 2024
              • 90
              • France
              #106
              Back on this topic to update.
              tv lasted 2 months and then back to black screen.
              I'll check in couple weeks if there is something wrong on DC to DC or of the second side of the panel is shorted now
              • retrorepair2
                • Feb 2023
                • 75
                • United Kingdom
                #107
                This TV was working ok after taping it for about 6 months but started doing the boot loop again so I removed the tape and tried this out which worked but now get the attached.
                Tried re-adding the tape (literally just blocked all control lines to the right side of the panel) but then get a completely blank screen.
                Bit bummed out, is the panel just toast now? I've reseated the ribbons but same thing.
                • Cornito
                  • Jan 2024
                  • 90
                  • France
                  #108
                  You can't block clock signals on both sides otherwise you'll get vertical lines or black screen.
                  if both sides are defective now, there is no solution.
                  • retrorepair2
                    • Feb 2023
                    • 75
                    • United Kingdom
                    #109
                    I've only blocked the right side clocks etc but then I get a blank screen. If I block none I get the result in the picture. This is with the VGH taped on the LVDS cable (there's no resistor on that board) and the signal jumped to the panel PCB test point as in the original post. In this case, anywhere from 1k to 100k works but I think the panel must have just now died
                    • Cornito
                      • Jan 2024
                      • 90
                      • France
                      #110
                      Did you retest from the beginning, with the jumper between the 2 test points with only one side connected, to check if there still a side which is working normally.
                      On TV i've saved (dead since, i'll need to confirm that the panel is definitely dead or not) first i've removed the limiter resistance on non working side,
                      Then I cut the VSS line, Then CKV lines that enter to the panel one by one, trying to make the cut reversible.
                      The cut to VGH to supply the line entering in the panel with the 14v coming from a capacitor next to the cutted line.
                      Regards
                      • retrorepair2
                        • Feb 2023
                        • 75
                        • United Kingdom
                        #111
                        This TV only has one LVDS cable, you can separate the sides on the filter board but it won't then turn on at all.
                        This is a UE70AU7100KXXU. Confirmed before doing it there was no voltage on the VGH test point on the main board and now there is but it looks like this
                        • Cornito
                          • Jan 2024
                          • 90
                          • France
                          #112
                          So this confirm the fact that it's on the main driver that you've got the issue.
                          I had the same case, I cutted the VSS line on this driver, that permitted to get an image, that was not good, I needed to cut CKV lines and link them to the ground to be able to get a not so bad picture quality.
                          • Cornito
                            • Jan 2024
                            • 90
                            • France
                            #113
                            You can check pictures i've posted on # 101
                            https://www.badcaps.net/forum/troubl...89#post3205489
                            Regards
                            • retrorepair2
                              • Feb 2023
                              • 75
                              • United Kingdom
                              #114
                              Didn't it die anyway? I may just let someone else have a go, seems like a lot of work for no real reward
                              • Storyteller12
                                • Jun 2020
                                • 624
                                This is a cheap TV with a known screen defect.
                                Not worth all the trouble to be honest. I appreciate the dedication to trying to find a solution but sometimes things just belong in the trash. This tv being one of them.
                                Between the bad screens, the backlights burning out and melting diffusers.
                                • Cornito
                                  • Jan 2024
                                  • 90
                                  • France
                                  #116
                                  you right, it's not a good TV, but anyway we spent money and that shit and if we can save some time before having to buy another one it could be great, this will reduce our wastes.
                                  I'll try to fix what can be fixed, and if there is nothing really acceptable, i'll resign to put this in trash.
                                  Samsung should be under class action for that mess
                                  • xfox
                                    • Feb 2018
                                    • 84
                                    Hello guys, so delay switch powered from USB is not working perfect, USB can randomly turn off while watching TV, I need to find some other 5v source, or 12v, have also 12v delay timer relay, any ideas where I can get 5v turn on? Also I was thinking ab 555 timer, need 1-2 sec delay, can someone suggest R and C for 1-2 sec?
                                    • Cornito
                                      • Jan 2024
                                      • 90
                                      • France
                                      #118
                                      Hi xfox,
                                      I've place a DC to DC step up between the 12V on the input from the mainboard to the VGL to avoid this kind of issue
                                      • xfox
                                        • Feb 2018
                                        • 84
                                        I just turned off Instant On option in Eng menu, now TV is working ok
                                        • papakarlo74
                                          • Dec 2022
                                          • Ukraine
                                          #120
                                          Thank you to all the guys posted above!
                                          5 cents from my side: to make a proper red color I've brute forced different values and found the best result for R13246 - 47K
                                          10K - TV did not start
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            09-06-2024, 06:20 PM
