LCD Digital Screen monitor help
  • el3ctroded
    • Nov 2008
    • 198
    Re: LCD Digital Screen monitor help
    I've had several devices I've tried to work on (not TVs) that had all part numbers sanded off all the chips. It's annoying.
    • PlainBill
      • Feb 2009
      • 7034
      That sort of crap has been going on for years, and is worse than annoying. The manufacturer is saying 'You bought it from us, and we own you.'
      I wonder if PCBONEZ was complaining about the manufacturer not putting their logo on SMD devices. On most of the packages they would have to come up with a special process; there is barely enough room to put two legible characters on them.
      PlainBill
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Those aren't that small.
        Fcon caps probably aren't helping anything.
        Mann-Made Global Warming.
        - Dr Seuss
        • pug_dari
          • Jun 2010
          • 11
          Without the schematic for that PCB no one can bee correct on the exact part replacement.
          • PlainBill
            • Feb 2009
            • 7034
            You're right. You might as well give it to someone who knows the difference between a diode and a transistor.
            PlainBill
            • pug_dari
              • Jun 2010
              • 11
              #26
              PlainBill
              Already been there to a "professional" and he blow-it up
              • PlainBill
                • Feb 2009
                • 7034
                I didn't say 'Give it to a "professional", I said "give it to someone who knows the difference between a diode and a transistor." All it takes to be a "professional" is a business card and a line of BS. There are many people working in electronics repair who understand electronics. Wizard is obviously one of them. There are also many whose strength is swapping parts until it works, writing inflated invoices, and coming up with reasons why you should pay them for NOT fixing it.
                My further point is that someone who cannot distinguish between a diode and a transistor is not qualified to decide my parts identification is incorrect.
                PlainBill
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • abajor
                  A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                  by abajor
                  Having this very weird issue.
                  The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                  I swapped with a working screen from an A2141 waiting for parts.
                  The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                  The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                  04-27-2024, 01:37 PM
                • 3D Modelka
                  AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                  by 3D Modelka
                  Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                  02-09-2024, 02:42 AM
