un55es6100 full time hum
  • vbrad511
    • Feb 2015
    • 70
    Hey all, we've got a Samsung un55es6100 that's started humming through the speakers, even when the power's off. The tv still functions as it should. Main board issue most likely?
  • nomoresonys
    • 12276
    • U.S.
    Re: un55es6100 full time hum
    simple test, if you haven't already, unplug all external devices, see if any change.
    • nomoresonys
      • 12276
      • U.S.
      you did put your ear to both speakers to make sure it's coming from them and not one of the internal boards?
      • vbrad511
        • Feb 2015
        • 70
        It was coming from the speakers. I unplugged the set a few times before I posted on here, but the buzz came back each time. After I posted I went back to check the things you suggested, but when I plugged it back in (after sitting for quite a while) the noise was gone. I'm expecting it to return...will update when it does. Thanks
        • Use2bavolvo
          Bad Caps affect on time / clock functions
          by Use2bavolvo
          can someone please help elaborate if a bad cap will affect time / clock functions. My fancy coffee machine has a preset pour for espressos's all of the presets are way out of wack what use to be 25 seconds is now 12.
          I am about to replace the psu caps but need some guidance if a bad cap would slow down or speed up clock functions?
          02-13-2023, 06:59 PM
        • titomno2
          Gaming Laptop Zephyrus S17 TFT not detected every time !
          by titomno2
          Hi guys,
          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
          Then the screen won't work for a long period of time.
          If I wait 1 or 2 hours it work again most of the time.
          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
          01-19-2025, 08:27 AM
        • flat-earther
          Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
          by flat-earther
          I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
          To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
          I have opened the camera and I think there is enough room to add something inside to accomplish this:
          The camera is powered by a 3.7V nominal single cell lithium ion battery.
          So I need to connect another battery in...
          06-08-2025, 02:00 AM
        • OscarAV
          HP Pavilion dm4-1065dx long time to get the power led on
          by OscarAV
          I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
          I have made a quick search for my laptop but I have not seen anything similar.
          I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
          09-23-2024, 05:53 PM
        • gshark1
          Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
          by gshark1
          Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
          12-29-2023, 04:42 PM
