Sharp LC-60LE452U Working (Not)!
  • Lupin3
    • Jan 2022
    • 29
    I just bought a Sharp 60" LCD tv that was not working at all: no standby light, no backlight, no video or audio. There is just a hum from the power board when I opened the back and plugged it in and to try to turn "on". I measured the standby volts (and the power-on volts) and when everything is plugged in, the volts fluctuate high and low near the expected 5V. Here comes the tricky part: If I unplug the Power Board line to the FRC Board and then plug the tv in, it automatically activates the standby light turning blue, the backlights turn on and the volts from the Power Board are steady. If I shut off the tv once again (the standby light is red keeping it plugged in), then replug in the FRC Board to the Power Board and turn the tv on, everything works as new! The only problem is that if I turn the tv off and then try to turn it on, it is completely dead once again!
    This is what's baffling me: which Board would prevent the tv to turn on normally considering it DOES turn on after replugging in the FRC Board if I follow the above steps???
    Any expertise would help me sleep at night...:
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sharp LC-60LE452U Working (Not)!
    Show the photo FRC board
    • Lupin3
      • Jan 2022
      • 29
      Here's the shot...
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        It is necessary to check the main power supply module why 5 volts are changing.
        • Lupin3
          • Jan 2022
          • 29
          Thanks for responding. Sorry, when you suggest the "main power supply module", do you mean something specific on the Power Board itself? I'm not too familiar with the component terms. Should I start with replacing the Power Board since it can't keep the power steady when I plug in the FRC Board?
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            … Show a photo of the power supply
            • Lupin3
              • Jan 2022
              • 29
              Where would I find the "U8, U4, U5, U6"? Power Board?
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                Main board
                • kasfamily
                  • Aug 2014
                  • 774
                  • Russia
                  Start checking with the power supply
                  • kasfamily
                    • Aug 2014
                    • 774
                    • Russia
                    Ps
                    • Lupin3
                      • Jan 2022
                      • 29
                      Power supply is putting out volts as indicated in diagram but fluctuate when FRC is plugged in.
                      • Diah
                        • Feb 2013
                        • 6614
                        its much caps issue at cold area power boards. V okay but lack with currents which caps responsible.
                        • Diah
                          • Feb 2013
                          • 6614
                          try heat the all caps at cold area with hair dryer and turn on see if it come straight on while FRC connected in place.
                          • Lupin3
                            • Jan 2022
                            • 29
                            Will do the hair dryer trick...here's what my Board looks like.
                            • Lupin3
                              • Jan 2022
                              • 29
                              3 pics to see the caps
                              • Lupin3
                                • Jan 2022
                                • 29
                                Success with the hair dryer!!!
                                Does this mean the Power Board is the problem?
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  one or 2 caps are at end life. no need to replace boards do it just caps. you can all replace with less 3$
                                  at yours photo its look 2 caps swollen up.. any in this shape change it
                                  • Lupin3
                                    • Jan 2022
                                    • 29
                                    Well, thank you for guiding me with the troubleshooting. You were a great guide A new Power Board it is!
                                    Aufwiedersehn!
                                    • lotas
                                      • Jan 2016
                                      • 4900
                                      • Russia
                                      The photo shows that five capacitors are swollen, well, it's better to replace everything.
                                      • Lupin3
                                        • Jan 2022
                                        • 29
                                        Much appreciated about the 5 caps - will replace the Board
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • brzostos
                                          HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                                          by brzostos
                                          Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                                          After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                                          Original HP 150W power supply, the diode in the power socket lights...
                                          10-01-2024, 01:34 AM
