Panasonic TC-P65ST50 plasma in protection mode after incident
  • HonkBeep04
    • Apr 2022
    • 9
    Hello everyone! I picked up this 65" ST50 plasma TV for $80 on Facebook marketplace two weeks ago. I have the basic electronic knowledge of a teenage computer geek, having assembled laptops and PCs and messed with soldering and software.
    This afternoon I decided to disassemble it to mitigate a buzzing noise. This is a well known issue for this TV ever since they were new. The popular solution is to replace the loose internal screws for ones with lock washers, preventing any future buzzing. I figured that I could just fully loosen and tighten all of the screws securing the sustain boards to make it go away. After doing so and putting on only the wall mount screws to secure the rear panel, I turned the TV on. I was disappointed because the effect of tightening the screws seemed to be minimal compared to beforehand.
    In the spur of the moment, I thought I could stick something into the vent grate to stabilize the board and/or feel the vibration coming off. My tool of choice was a metal allen key and I stuck it in and touches one of the hollow metal arches marked on the circuit board for high voltage. Of course, there was a fat spark and a loud bang, and the panel immediately went totally black. I cannot say there was any fault but my own here; my only hope is that I learn a hard lesson not only of proper conduct but also how to fix the mess I've made.
    I took it back apart but I couldn't find any visually bad components or tested bad fuses. I figure anyway that a failure that immediate wouldn't blow a fuse or cause a capacitor to fail in a visible way. I put the TV back together to start doing research.
    When it's first plugged in, a relay clicks regardless of what else goes on. When the power button is pressed, a relay clicks but then clicks off again after a few seconds. The power light blinks in sets of three repeatedly. I found one source that instructed reset it by unplugging the TV, holding down the power button, and then plugging it in and holding it. When I did that, the relay still clicked when it was plugged in, but the power light and the other relay didn't come on until it was released.
    I found this link showing that the 3-blink alert on a concurrent model Panasonic meant a failure of the A-board.
    https://www.reddit.com/r/TVRepair/co...changeability/
    However, every other piece of information I can see seems to point to the power supply board. The hope would be to repair some superficial component, but really I just want to see if this will be worthwhile to fix. Thank you to anyone who read this far and for any information provided. I am grateful for the wealth of information available on this forum.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Panasonic TC-P65ST50 plasma in protection mode after incident
    You turned something that could become a problem, into a very difficult or costly repair.
    If you poked into the SC board, the 3 blinks signal is from the power supply, because the VSUS output is shorted, your SC board has shorted components, which are hard to repair and this board is rare.
    • HonkBeep04
      • Apr 2022
      • 9
      Thank you for the reply. I found an SC board on Ebay for a price I would be willing to pay to fix the TV. Perhaps I will peruse some guides to see if there is a way to confirm the failure.
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        open the back and unplug the cable going from the power supply to the SC, if the blink code changes the SC is the problem.
        The service manual says that 3 blinks is from main board, but you need to try this test before.
        • HonkBeep04
          • Apr 2022
          • 9
          I took the back off again and found that what I touched was the SS board. I unplugged it and the blink code changed to 8. I then plugged it in and unplugged the SC board, and the blink code went back to 3.
          I would normally assume that the blink code not changing when unplugging a bad component would mean that the component is indeed bad, but I think I understand what you are saying. With the power going to SS, the main board can detect a fault, whereas with power cut it detects only a lack of communication and thus sends a different code. Assuming my understanding is correct, if the board were good then the code would not change because the problem is more severe with another board.
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            This tv may power up without the SS, unplug all cables going to it.
            If it does not work, then you can power up the PSU + motherboard only by unplugging the 3 ribbon cables that goes to the C boards and SC.
            • HonkBeep04
              • Apr 2022
              • 9
              I unplugged both the power cable and the ribbon cable going to the A board and plugged in the TV. When turned on, it showed a dim, purple image of the no signal screen. I assume this means the SS board is bad then, I should be ordering one soon.
              • HonkBeep04
                • Apr 2022
                • 9
                I've been looking on eBay for replacement boards, and I found by searching the model number that there are varying prices for the same model number (TNPA5648) board with a different "order number" stamped on. Mine is AE and other P65ST50 boards are also AE. Some P60ST50 boards are AF and some are unmarked. The boards from the P60GT50 are usually AB, and I have also seen an A3. I should generally assume that this order number means no interchange, correct? The AE seems to be the most expensive.
                Edit: I have just noticed that the GT50 board has more components noticeable like an extra capacitor and metal loop thing.
                Last edited by HonkBeep04; 04-28-2022, 10:08 AM. Reason: Just noticed extra information
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  Only the SS board is defective, lucky.
                  You should use an AE variant then, the others will require some changes in component placing.
                  The screws repair is done by swapping them with screws of proper length with washers, cleaning the ground pads on the boards and on the TV metal frame itself, look at this blog post for more information https://alpengeist-tvrepair.blogspot...d-7-blink.html
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    I have the same tv. Got it with the blown power supply capacitor, driver ic,(str y6766) and the fusible. 56 ohm resistor.
                    I found the 331 2kv capacitor and the str y6766 ic in my spare parts. Only thing I could find for the resistor was a .22 ohm.
                    I put it all back together and the tv turned on and looked great for about 7 minutes. It blew the controller ic again. Does anybody think the fusible resistor was the cause of the failure?
                    I can't find a replacement anywhere.
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      The original resistor was 0.56 and you replaced with 0.22? Is this the one that goes to the drain of the main switching MOSFET? If it is then it's clearly the resistor.
                      • R_J
                        • Jun 2012
                        • 9533
                        I agree, the source resistor voltage drop is monitored by the ic and changes its operation based on the mosfets current. You say it blew the controller ic again, did the source resistor also go open? You don't say the wattage but digikey has 560mΩ (0.56Ω) resistors, I would try for a non-inductive or use a metal film type
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          The replacement resistor (.22) did not go open. It is circled in red.
                          • Biruslapio
                            • Nov 2013
                            • 552
                            • Brasil
                            Ah correct, the resistor is connected to the Source not the Drain.
                            It would only go open if the mosfet also blew, since only the driver had problems, you can try to do an association with parallel or series, just need to match very close to the 0.56 ohms and power rating of the original resistor.
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              I bought a .56 ohm 5w and a new str-y6766. I'll report back when they arrive.
                              • R_J
                                • Jun 2012
                                • 9533
                                R414 is not the source resistor it is just a fusible resistor in the supply voltage line. The source resistor is R403, I would check that resistor and the diode D411, If the ic shorted, D411 may have shorted and now R403 would be bypassed by a shorted diode. With pin 2, S/OCP connected directly to ground and not through the resistor, the ic can't monitor the current.
                                I should add that having a lower resistance for R414 should not have caused a problem.
                                • HonkBeep04
                                  • Apr 2022
                                  • 9
                                  The SS board arrived today. I installed it and all is going well. I also ordered one of the official Panasonic part number screw packs, but when I got them they were way longer then the existing ones. I didn't want to take the chance on breaking the panel, so I put in the old screws. The new board has very little buzzing so I'm pretty sure it was actually caused by the coils going bad, which is another common failure for these TVs later on.
                                  Thanks so much again for your help. You really saved me a big headache!
                                  • jm1234
                                    Panasonic plasma TX-P42ST50 - 6 blinks
                                    by jm1234
                                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                    I checked that board for any obvious faults...
                                    05-22-2024, 06:59 AM
                                  • stecos
                                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                    by stecos
                                    Hi everyone!
                                    I happened several times, in the search for help from the web, to consult this very interesting forum.
                                    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                    Having said that I come to the gist of my post on the forum as the title suggests.
                                    For my passion for technology I'm now collecting several...
                                    11-28-2022, 11:39 AM
                                  • Alicat
                                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                    by Alicat
                                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                    Model number is TH-50PZ85U
                                    Power comes on and the red power light stays on solid.
                                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                    I also hear a few clicks.
                                    I also think my parents said there was a thunderstorm and the TV failed after that.
                                    Section 6 in the service manual talks about power and no screen,...
                                    10-30-2024, 10:09 AM
                                  • Lintesir
                                    Panasonic P42S30 Plasma - Pink sparkles
                                    by Lintesir
                                    My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                    There is about a 5cm high region at the top without any sparkles,...
                                    07-26-2024, 03:16 AM
                                  • badcappo
                                    Dead Panasonic Viera TX-P65STW50 Plasma TV
                                    by badcappo
                                    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                    Diode type G972s6 - D101 with a short
                                    Mosfet 06N90E - Q301 shorted
                                    Fuse T5AH 250V - F103 blown
                                    Diode D301 shorted
                                    Relay DG1U-17VDC II - RL001 blown
                                    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                    11-24-2024, 11:27 AM
