Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
leave it.... do the following to force the tv power on and reset fault in case there are error at BL
remove all jumpers.. and plug every things as original. plug the tv out from wall socket.
While holding down the “VOL (-)” and “CH ( - /down)” keys on the set at once, plug in the AC power cord to turn on the power.
After a central icon flash off, separate the fingers from key on the set.
Then, you can check the operation to see if the lamp and lamp circuit are in trouble.
If you fail boot-up, retry the procedure.
page 44 service manual
EDIT:
could be this oneLast edited by Diah; 04-20-2022, 09:48 AM.Leave a comment:
Any last attempt can be done on this old MB?Leave a comment:
Cool man, I am newbie in TV also I have attempted a few repair..
I appreciate all the guidance you have given. Yes, I have taken your word that the MB is busted and will need to source one.
I also want to be certain that backlight of PS is good too. BL is not on, I think it is worth investigating before buy a new MB right?Leave a comment:
Dimm when it low mean LED ON. if dim go high mean cutoff.
SPI= eeprom SPI FlashLeave a comment:
men... you are really funny... who care on BL if they come on or not when the MB dead.
did you know which pin BL_ON ?? we tested panel 12V. and main 13V are good mean PCB 100% working
what the diffrent if man his legs brocken and you insist to teach him dancing !!!!Leave a comment:
Black probe on big cap negative, red on middle pin of Q7700 - 402VDC
Black probe on big cap negative, red on either pin of Q7700 - 0VDC
Repeated a few times..
How does this Q7700 works?Last edited by beetle1303; 04-20-2022, 09:11 AM.Leave a comment:
what happened? beer break?Leave a comment:
make sure your meter is set to at least 200 if it isn't an auto range meter.Leave a comment:
test q7700 again, put black probe on neg. of big cap and red probe on each leg of that fet.Leave a comment:
There is no power supply to those 2 transformers, because Q7700 is either faulty or not triggered?Leave a comment:
I am not getting any voltages on those 2 transformers. And you're right, after tracing the 400Vdc from the big caps to the component Q7700, and 0v output to the transformer.
I tested this transistor:
1) Red probe on middle pin:
Black probe on either pin - Open
2) Black probe on middle pin:
Red probe on left pin: 528
Red probe on right pin: 732
Does it sounds bad or OK?Last edited by nomoresonys; 04-20-2022, 08:54 AM.Leave a comment:
wondering why the backlights didn't come on when powerboard is jumped, sure seems like they should.Leave a comment:
But I also curious about whether the BL is working since it has no power to he BL section of the PS.
From my precedent replying post - does it looks like BL is not working?
Question: What's a SPI ?Last edited by beetle1303; 04-20-2022, 08:31 AM.Leave a comment:
Does it sounds bad or OK?Leave a comment:
power boards are fine...
yours problem at MB, didn't send PS_ON... could be the MB tosted / dead or the SW or too the SPI flash.
the front LED when it blink its the first boot sequences of the SPI which it didn't complete... try freeze the SPILeave a comment:
if you still have no voltage when powered, maybe trace it to where it stops, which seems to be right after the big caps somewhere in that area.Leave a comment:
you should be getting voltage on some of those, on hot side you use the negative of one of the big filter caps as ground, so neg. probe on that and pos. probe on what you're checking.Leave a comment:
I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
Observations... -
by triplefourHello all
got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
anyway i go to this guys house to look at an ONN 100012588
this is my first time looking at one of these brand of TV's.
TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to... -
by beetle1303My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
Checking further on the primary side: Incoming line input to bridge... -
by ronelexHello
I got this unit with orange light but wont boot up
I notice that its L7560 3.3v supply is fluctuating
this is the reading I got on its PWM U7501 TPS51890A
pin 4- EN1 - 0v
pin 12 - EN - 3.3v Fluctuate
pin 21 - EN2 - 3.3v Fluctuate
pin 22 - vreg3 - 3.3v ok
pin 23 - vin - 8.62V
pin 29 - vreg5- 5v fluctuate
I already check the power rails line in page 62 but I didn't find any short on those lines. I already tried replacing the pwm but same issue.
I hope you can guide me where I can look for the fault of this... -
by mferna14Hi all., I am working on a MacBook 12" Retina Logic Board # 820-00045-A. It does not turn on. The Amp meter show 20v & the amps are around 0.01 ~ 0.05V . Upon checking all the power rails, till PP5V_S4 all is fine, getting full stable 5V on this rail but when I check PP5V_S0, it is fluctuating 5V , after a sec it goes to 0V & comes back again to 5v. This is happening continously. I checked for any short to GRD in diode mode but none. For where is this PP5V_S0 generated?? No liquid spill, logic board is very clean. Any help or tips will be great appreciated. Thanks
- Loading...
