Pioneer PDP-V402 - Black Horizontal Lines
  • Wf789
    • Apr 2022
    • 5
    Hi, I'm new around here and hoping that there may still be some people on here that are knowledgable about plasma display repair, as some of the old badcaps forum posts have been pretty useful to me so far.
    For any regular plasma TV I probably wouldn't bother to go through this effort, but I have a pro-grade Pioneer plasma which I really want to use and it would be a shame to throw it out since there's not many of them still around these days. The plasma has the typical black horizontal lines that seem plague plasma displays. I've counted 3 lines on top of the screen and 4 at the bottom. The previous owner said they were initially intermittent, but in my experience so far they haven't gone away.
    From reading other posts, the usual causes for these black horizontal lines seem to be either:
    A. Dirty ribbon cables/connectors that connect the Y-Buffer boards to the panel.
    B. Faulty ICs on the Y-Buffer boards
    C. I've seen numerous people state that the panel can “go bad” and the lines can appear (not sure if this is even true) as no real explanation was given.
    D. Saw one mention of the digital board, but I haven't looked into this yet.
    Regarding C., I've seen the ribbon cables either blow out due to overheating or corrosion on the panel side, so perhaps this is what those people were referring to. I'd assume this is repairable under the microscope but I'm not sure whether or not the ribbon cables on the panel side are typically accessible?
    So far I've reseated and cleaned the top & bottom ribbon cables, twice, with no luck or change whatsoever. Moreover, I've tested the top & bottom Y-buffer boards for any shorts, along with a visual inspection and everything checks out just fine.
    The next thing on my list is to get to the panel and inspect the ribbon cables there (if they're even accessible). I'm wondering if anyone has any other recommendations on a possible fix, or something else to look at before I go through the effort to strip it down to the panel.
    Any comments are much appreciated.
    Best regards,
    William
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Pioneer Plasma - Black Horizontal Lines
    No model mentioned and no photos.
    Definitely nothing to do with Y boards, it's panel or the COFs that come out and connect to the upper and/or bottom boards that have a large horizontal heatsink.
    • R_J
      • 9624
      You can either try replacing the buffer board, or you will need to scope the drive signals going to the panel to prove 100% where the problem is. Yes the panel can go bad and cause this, some Samsung 50" plasmas had this problem.
      • Wf789
        • Apr 2022
        • 5
        Thanks both for your comments.
        Apologies, for not including the model & photos. Here model no. + service manual:
        https://www.manualslib.com/manual/11...-Pdp-V402.html
        Pictures of internals and lines attached. Please ignore the yellow tint, the image is white in real life. It's just the camera.
        Sad to hear it may be the panel, but that's what I expect to be honest. I still think it could be the ribbon cables which connect the Y buffer boards to the panel though.
        The unit has 6490 hours on it which is not much but these can get quite hot hence the 7 fans.
        You really think replacing the buffer board is a good idea? I recently got a scope so could give that a try first…
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          Okay, for some reason I read vertical lines, sorry.
          It has to do with panel, Y-buffers, Y-SUS,or logic board.
          Each pin that the buffers connect to the panel have a forward voltage that can be measured by a multimeter, if it measures open, then the board is faulty.
          To test it you put a multimeter in diode mode, place positive lead on Y-Buffers floating ground, and negative on each pin that connects to the panel, it must give a voltage of 0.6~1.0V
          • Wf789
            • Apr 2022
            • 5
            No problem.
            Funnily enough, I spoke to a repairman who used to work on these. He said:
            "Best guess, it's one of the IC scans but difficult to know for sure without having the panel here. You could look closely at each chip and see if there's a hint of a circle in the middle, could be a sign of failure. The board they're on is bonded to the glass so it means a component level repair or scrapping the panel."
            Perhaps he also is thinking it's vertical lines... Also I have no idea which board he is referring to as I haven't stripped the monitor down to the panel yet.
            As for your suggestion, so far I've only done a continuity test between GND & each of pin that connects the buffers to the panel. I'll try and put it into diode mode and measure as you suggest on the weekend.
            Will post back with results
            • R_J
              • 9624
              Re: Pioneer PDP-V402 - Black Horizontal Lines
              Looking in the service manual, the lower scan modules (A) (AXF1104) are both the same but different from the upper scan modules (B) (AXF1105)
              So you should be able to swap the upper modules around with each other.
              DO NOT swap a lower board with an upper board
              • Wf789
                • Apr 2022
                • 5
                Yeah, those are the Y-buffers. There are four of them, two top and two bottom. Each set does indeed have different part no's, but otherwise they're visually identical.
                I removed one yesterday to inspect it, but didn't think to swap the upper modules around with each other, then try the same with the bottom pair. That's a good idea to rule out these boards.
                Sadly I don't have the space on my bench during the week to work on this so will report back with results this weekend!
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
                • CyberNinja
                  Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
                  by CyberNinja
                  First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
                  01-10-2021, 09:38 PM
                • noisykid
                  Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                  by noisykid
                  5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                  12-30-2024, 07:15 PM
