phillips 37fd9954 plasma tv
  • cadiman
    • Mar 2010
    • 397
    This is a 37" phillips plasma 37fd9954/17s with the common power supply problems. It has an mc34067p ic. These fail along with the caps near the heat sink. Has anyone run into this and are schematics anywhere to be found? I did find a data sheet on the ic and plan on starting from there. I am looking for a little more info on this power supply. The front half seems to be working fine running around 330vdc, but I can`t get much out of the second half. I think the ic is shutting it down or not letting it start up. Thanks, Cadiman
  • Zelek11
    Panasonic Plasma screen interference on left half of screen
    by Zelek11
    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
    10-14-2022, 04:54 PM
  • renech
    panasonic TH-42PC77U plasma television half screen problem
    by renech
    hello,
    I hope someone on this forum can assist me.
    I have a panasonic TH-42PC77U plasma television.
    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
    I have read some posts that suggest the problem is related to the boards on the left...
    12-12-2022, 06:53 PM
  • Raulnn
    TD Systems K50DLG12US half black and half white screen
    by Raulnn
    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
    01-20-2024, 04:49 PM
  • Uranium-235
    Phillips 50PF7321D/37 Plasma slow reboot
    by Uranium-235
    Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
    12-27-2021, 09:14 PM
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
