LG 32LJ610V with the blue tint of death. LED replacing...
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi There!
    I own the above mentioned LG set, that suddenly one day started showing all colors faded to blue. I messes with all possible parameters in the menu with no effect.
    Then I looked up online and found that this is a common problem with some of the LG sets that were using a specific brand for their LED backlight.
    I plan to repair it, but I would like to use your experience if you've done this before
    1) Does the issue apply to all the LEDS at the same time or can I just expect to have to swap a couple of them?
    2) Can I anticipate the model number for the leds inside? Or should I go for complete (more expensive) comercial strips?
    Im asking as this would be the second time I open the backlight LED area and it's a little tricky having to handle all those ultra thin and delicate layers of plastic&LCD, so I would like to open it just once and change it all with all the needed parts at hand.
    Any hint will be greatly appreciated!
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 32LJ610V with the blue tint of death. LED replacing...
    A 32 inch TV is relatively easy to work with a lower risk of cracking the screen though you still need to be careful. Just replace all the strips with new and turn down the backlight level.
    https://techhometravel.com/lg-49uj65...e-purple-tint/
    Looks the style of LEDs that turn blue.
    https://www.ebay.com/itm/202693007071
    • edugimeno
      • May 2017
      • 581
      • Spain
      Thanks for th website and link. I see from here that it's not the LEDS but the color filter they placed on them. Anyway I need to change them all.
      Ok I found just by looking up "32LJ61" at Aliexpress that they too sell them at cheaper prices. I guess I will take my time to open it all up one time to see how manu strips and length, and then order whats required.
      Thanks!!
      • edugimeno
        • May 2017
        • 581
        • Spain
        Ok I found some time and disassembled down to the led strips. You are right, a 32" panel is not so delicate. Last time I did this it was a 42" set
        I found 2 strips of 5 leds each. BTW they don't show like the ones in the link above, just normal clear white leds with the difusser plastic on top, no color filter at all.
        Anyway, should I just go ahead and replace them? They have 32LJ61 printed on them and there are tons of items on AliX and Amazon selling this.
        Thanks everyone
        • dskall
          • Oct 2016
          • 2905
          • usa
          So you don't have a backlight problem?
          • edugimeno
            • May 2017
            • 581
            • Spain
            I thought I did, as I have this TV showing all in blue tint...and all forums I've checked on LG sets showing blue colors advice to swap led strips. What Im saying is that my led strips are not at all alike to those in the web linked above, they are just plain white (I mean while powered off)
            • edugimeno
              • May 2017
              • 581
              • Spain
              Ok I found it IS the led strip itself. I applied some DC power to each individual LED in both strips and they show completly BLUE.
              See attached photo.
              Any advise on specific strip to buy? Or just any that shows 32LJ61 on it and comes in a set of 2 x 5 leds each?
              • dskall
                • Oct 2016
                • 2905
                • usa
                As long as they match your strip numbers.
                • neilc6
                  • Nov 2015
                  • 1550
                  You can turn the TV with the panel off on most TVs to test the backlights. Easier on Samsungs since you can just unplug the the main board cable. Maybe not clear but the pictures of the LEDs in the first link are shown with the lenses removed.
                  • edugimeno
                    • May 2017
                    • 581
                    • Spain
                    Ok I see. I just tried to remove all the lenses in one of the strips, and as soom as I wiggle the lens to detach it from the board, I get some yellow "sand" falling from below right before the lens detaches. I guess this yelloy sand is the filter that had got burned
                    It makes sense
                      • 12332
                      • U.S.
                      Indeed, they wear out the yellow burns off and the blue is what's left.
                      • angelos
                        • Dec 2012
                        • 573
                        • South Africa
                        The layer on top is phosphor that filters the blue led light into white. Apparently all led's are blue emitting diodes. Its the phosphor that changes it to white. In your case due to overuse the pgosphor has disintegrated so you now se the blue.
                        • edugimeno
                          • May 2017
                          • 581
                          • Spain
                          Ok, yes I understand.
                          Here's the thing now. Trying to save as much $ as I can on this repair (for a TV that's probably not worth $30 right now), Im searching for a reasonably cheap led strip. All I can find are pairs of led strips around $10-15 with the 32LJ61 marking BUT with 7-8-9 LEDS on them, instead of 5 LEDS as the original one has. Should I care for number of leads assuming that the resistor on the strips acoomodate the voltage to whatever leds they have? Or should I try to find the same number of LED on each strip?
                          • edugimeno
                            • May 2017
                            • 581
                            • Spain
                            Never mind, I just found a set of 2 strips with 5 leds each at 9$ total.
                            • Chungalin
                              • Jul 2014
                              • 423
                              • Spain
                              Never thought about this, but today I’ve opened a Samsung UE40J5200AWXXC with bluish backlight. The first surprise is to find some LED totally blue, while others are still perfectly valid white. When looking carefuly, I’ve found several yellowish tiny squares (about 1.5mm side) fallen inside the backlight chassis. These squares glow white when exposed to blue LED light, and if I put one of these squares in front of the blue LED, it turns white! So, in this case, the failure is simply that these phosphor "filters" fall off from the LED, because the LED has always been blue.
                              Actually, they’re not "filters". You could filter white light to obtain another color, because white contains all other colors, but you cannot filter blue light to obtain white. Blue light from the LED stimulates phosphor to glow white. Well, it actually glows yellow and adds up to the blue light that passes through, resulting in white light.
                              In attached image we can see the raw blue LED and the fallen glowing phosphor caps.
                              • edugimeno
                                • May 2017
                                • 581
                                • Spain
                                Hola compaƱero compatriota
                                Yes since I fixed the TV set that started this thread, I've had to repair maybe 4 or 5 with the exact same problem.
                                I was at a camping ground last summer and the tent next to us had a TV showing all blue, I told my son go check the brand of that TV set, he came back and said "Sure enough, it's LG"... Exact same thing happened one month later at the hospital, 100% blue TV, it was LG
                                Anyway since that time I've also found this issue on Samsung TV's as well.
                                By the way, everytime I've had to fix this I've found the backlight setting to 100%. I turned it down to 50% after the repair, and told the owner that having the BL to the MAX ensures this problem will happen again soon, try to keep the BL as low as possible
                                • jimbofz
                                  just a quick question do all qled leds appear blue when fault finding ?
                                  by jimbofz
                                  i have replaced many leds strips that have changed blue when they are worn
                                  and the new replacements are perfect white
                                  but when fault finding do quantum leds always look blue?
                                  08-28-2024, 06:51 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                • VitalComputing
                                  Replacing Mode Indicator LEDs
                                  by VitalComputing
                                  I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                  I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                  I thought I could just put a resistor...
                                  09-17-2023, 04:43 PM
                                  Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                  This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                  09-07-2024, 05:50 AM
                                  Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                  09-07-2024, 05:00 AM
