FN155 replacement
  • angelos
    • Dec 2012
    • 573
    • South Africa
    FN155 replacement
    Hi all, i have this toshiba tv that uses this transistor on the power supply. Its function is to feed the supply voltage to the STRF6268. I cannot get any clear info on it. Its apparently used in a Sony KV2167MT.
  • lotas
    • Jan 2016
    • 4899
    • Russia
    Re: FN155 replacement
    FN155 can be replaced by 2SC4633.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • Goldenmonkey
      Samsung pn59d530a3f no picture after power supply replacement
      by Goldenmonkey
      My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
      after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
      Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
      04-07-2023, 09:39 AM
      07-01-2024, 06:34 AM
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
