hitachi plasma line across screen (pin stripe)
  • cadiman
    • Mar 2010
    • 397
    I am looking at another plasma hitachi tv with a line across the screen 55hdt52 I don`t know if this pdp is a pioneer or not. I don`t know if the ics are part of the pdp or not. I think this is around 2004 or 2005 not sure.
    Thanks, cadiman
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • Eaglecrest
    Panasonic plasma color stripe
    by Eaglecrest
    I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
    11-05-2025, 06:16 PM
  • bffargo
    2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
    by bffargo
    LG 60PB66550 NOV 2014
    PSU: EAY63168603
    PCB: EAX65359531 2013.11.01 Rev:1.0
    Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
    Symptom:
    While watching, just went black and started clicking relay every few seconds.
    Initial diagnosis:
    Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
    Deeper diagnosis:
    Pulling pins #1/#2 (Blue/Grey) from the connector housing...
    09-09-2022, 07:34 PM
  • Yanleb
    Hitachi Plasma TV 42HDT79 firmware upgrade
    by Yanleb
    Do you know where I can find a firmware upgrade for the Hitachi 42HDT79 plasma TV? My set currently has firmware V0112.0001.
    Their service website seems to be on SalesForce now, which requires a login.
    Thanks.
    11-05-2021, 11:55 PM
  • cubytus
    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
    by cubytus
    Hi to all,
    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
    01-10-2024, 01:26 AM
