Samsung TV LT24e310nd/ZA backlight bleed or Bad CFL??
  • comi66
    • Mar 2013
    • 3
    Hi to all.
    Just picked up 5 of these Samsung TV's model LT24e310nd/ZA ' They all have the same issues. Screen has bright white strip on the right side and rest of the screen has a yellowish hase.
    Tried reset to factory defaults.Different power supply. Same issues.
    Please help. Thanks in advance.
    • 12181
    • U.S.
    Re: Samsung TV LT24e310nd/ZA backlight bleed or Bad CFL??
    Try a firmware update on one of them, see if it helps any, these seem to be led lit tv/monitors.
      • 12181
      • U.S.
      Maybe this will help, not sure, I see an option for live chat etc.: https://www.samsung.com/in/support/t...test-software/
        • 12181
        • U.S.
        https://www.samsung.com/us/computing...lt24e310nd-za/
          • 12181
          • U.S.
          Perform the Picture Test and to see if your TV is displaying the test image properly.
          Go to MENU - Support - Self Diagnosis - Picture Test
          If the test image is properly displayed, the poor picture may be caused by the source or signal.
            • 12181
            • U.S.
            Color temperature refers to how red (warm) or blue (cool) the color palette is. This control helps you to adjust the color settings on your TV. You can change the color settings by following these steps:
            Using the TV remote, select settings and look for a menu item labelled video or picture.
            Select Color Temperature. A slider should appear that allows you to slide between cool and warm colors. The colors might also be labelled red or blue.
            Slide the settings away from red/warm and towards blue/cool using the remote control. You can leave the slider at the point where the color suits you.
            Adjusting the Hue
            Adjusting the hue is just like adjusting the color temperature. In this case, the color extremes are between red and green. So, if you don’t like the result after adjusting the color temperature, you can adjust the hue by moving the slider towards the green extreme.
              • 12181
              • U.S.
              Try a different source, like antenna, dvd player, cable pc or different pc, etc, to make sure it's not just having trouble with the source.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Are these edge lit?
                  • 12181
                  • U.S.
                  Didn't see anything describing the backlight array, I'm guessing it's not edge lit because it's over 2 inches thick??
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    I think I would pull panel and have a look at backlights. It's a small monitor, so shouldn't be to difficult.
                      09-07-2024, 05:50 AM
                    • C152Heavy
                      by C152Heavy
                      Summary for TL-DR readers:
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
                    • sansanpartida
                      Samsung QE82Q70RAT no backlight
                      by sansanpartida
                      Hi everyone!
                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                      My issue: No backlight.
                      Model: QE82Q70RAT
                      Type No: QE82Q70RAT
                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                      So hopefully, I can fix this cheaper.
                      05-22-2024, 06:56 AM
                    • howardc64
                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                      by howardc64
                      TV was fixed just after removing Samsung's rear snap cover.
                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                      Maybe PSU->backlight connector didn't have a good contact?...
                      07-23-2025, 12:34 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
