Samsung UE40JU6400K - no image.
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    40" Samsung UE40JU6400K
    initally no backlight, but can hear sound.
    unplugged TCON and backlights come on. but no picture.
    plugged TCON back in and removed 1 of the 2 panel connections, backlights come on. but no picture.
    tried other panel connector on its own - same, backlights on, no picture.
    but.. plug both panels connections in and no backlights.
    found a shorted SMD capacitor on right panel board , removed and waiting for a replacement to turn up.
    in the meantime - why is there no picture at all ?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung UE40JU6400K - no image.
    does the tcon fuse test ok (usually near lvds connector)
    i have had this issue recently on a panasonic set and was a faulty tcon
    • stav242
      • Jan 2014
      • 61
      • United Kingdom
      TCON fuse is good. 12v on both side.
      have actually swapped the TCON with another board now.
      same result.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Check that you have lvds signals going into t-con. Should have around 1.5v on each.
        • stav242
          • Jan 2014
          • 61
          • United Kingdom
          Ok. No lvds 1.5v signals.
          I've got 12v and 3.5v on the tcon.
          Is this a MB fault then?
          • dskall
            • Oct 2016
            • 2905
            • usa
            That would be my guess.
            • rimwall
              Sony KD-65x7500D - double image - Tcon or Panel?
              by rimwall
              This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
              I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
              Today, 02:09 AM
              09-07-2024, 05:50 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • stinger
              Samsung UN70TU6980FXZA no sound no picture but does have backlights
              by stinger
              When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
              04-17-2024, 03:06 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
