panasonic TX-43GX550B
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Hi guys i picked up this 4k lcd tv up yesterday with a backlight fault (vestel connection joint issue hard wired strips also replaced one strip) the tv was working fine nice picture etc.
    come this morning i thought i would leave it on soak test but now a problem the set comes out of standby the led then goes a solid green and the backlight works and stay on, the issue no picture at all now.
    i have tested all the voltages from the psu and they seem fine. I have also checked i have 12v too both sides of t con fuse which i do.
    I have removed one top ribbon cable and turned the tv on no change, i tried with the other ribbon cable removed no change, as no white half screen at all could this be a mainboard issue it uses a Vestel 17MB130S Main Board.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: panasonic TX-43GX550B
    I would be checking t-con voltages.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      you correct thinking tcon i was just about too check voltages when i spotted a really small bga ic with a hole in it, luckily on ebay i found same tcon for under £10.00 delivered so worth a try odd it was working yesterday but i did notice some flickering on the picture so was probably failing then.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Update, the secondhand tcon arrived fitted it and now have picture back, (could me running the set without the lcd attached caused the tcon to fail as i let the set run for a while too make sure no backlight issue was fixed) the tv still has a picture flashing issue on top left of screen, so i have just ordered a new led strip kit (4 strips) just a waiting game now as from china.
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • luis71
          PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
          by luis71
          Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
          I have backed up PQ,SPI,and Profile if anyone want
          Which usb_auto_update_??.txt can i use to dump firmware?
          I would be grateful if anyone could help me to find the firmware for USB recovery.
          11-05-2023, 06:31 AM
        • ResetReality
          Toshiba/Vestel 58UL2B63DB Wifi Issue???
          by ResetReality
          Hello fellow tech heads.
          Had this tv come in...issue stated reboots on wifi.
          Indeed it does. However, with wifi off or using cat 5 cable no reboot issues.
          So far ive changed mainboard and wifi module...also reset tv back to factory via service menu (4725)
          Still same issue... i do have a psu to swap but cant see it being that really as works flawless if wifi is disabled
          I thought fireware? But why only on wifi?
          Is it an issue with the memory cache filling up and having to reboot for more ram??
          At a total...
          07-04-2024, 12:28 PM
        • piernov
          Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
          by piernov
          Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
          I suspect corrupt firmware but I haven't been able to find anything for this TV.
          TV model: Finlux 65-FUC-8060
          Mainboard: Vestel 17MB130S 23473048
          Panel: VES650QNTS-2D-U11
          At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
          06-01-2024, 12:57 PM
        • Ancient1
          I'm stuck . Panasonic TH-L32U20M panel's boards issue
          by Ancient1
          Hi
          The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
          Actions :
          1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
          1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
          Obviously the fault is from or on the Right, secondary board
          2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
          09-03-2023, 03:51 AM
