LG 49UJ651V vertical lines
  • dkmorb
    • Dec 2021
    • 4
    • Italy
    I am new here, this is my first post on Badcaps forum!
    I have a problem with this LG TV: vertical lines on the panel!
    Sometimes if I move the flat cable from the logic board to the panel, the image appears correctly!
    I have already cleaned the plug contacts with isopropyl alcohol...
    Any idea about?
    Thanks in advance!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 49UJ651V vertical lines
    Try cleaning contacts with an eraser.
    • dkmorb
      • Dec 2021
      • 4
      • Italy
      I tried but nothing... I read somewhere that the problem could be caused by that damn ribbon cables ...
      • TeslaMichael
        • Oct 2020
        • 102
        I don't know if this works but you could try to fix it with tape. Look for a Position where image is ok and then use tape, that the ribbon cable won't Move. Or get a replacement cable.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • Firentiosi
          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
          by Firentiosi
          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
          The issues are as follows: the...
          11-27-2024, 12:33 AM
