Vizio M421VT Pic with interference help
  • ivtec
    • Dec 2008
    • 1967
    Hi guys hope you all are having a marry Christmas ,i have here a Vizio M421vt that started to have some interference in the pic, nothing else is wrong ,i send a Utube video with the fault.Any clues and help would be appreciated.
    https://youtu.be/YW1QeeCoSDA
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio M421VT Pic with interference help
    Can't say much for your choice of programs. Looks maybe like gamma problem.
    • ivtec
      • Dec 2008
      • 1967
      Thanks bro ;Not my fav channel either. Unless it's airing the Patriots game. just picked up this channel from off the Air Ota antenna to make this video,
      So you say it's gamma issue so the only way to fix is to change main board?I thought gamma issues was like this?https://www.youtube.com/watch?v=BieS43QlC6w
      • dskall
        • Oct 2016
        • 2905
        • usa
        Video was kinda from side. I would try cleaning ldvs cable and see if it helps.
        • ivtec
          • Dec 2008
          • 1967
          Cleaned up lDVS not helped ,strange this tv has a PC board and not a T-con board,i guess it's T-con and pc board ,https://www.ebay.com/itm/37267910603...MAAOSwxYRc7PmV
          • dskall
            • Oct 2016
            • 2905
            • usa
            Still looks to be a t-con under the shield. So is video showing a red tint? Maybe remove shield.
            • ivtec
              • Dec 2008
              • 1967
              Hi mate, no the pic if perfect exept for that interference ,there is no T-con under the metal shield ,Pc board is both PC and T-con i guess.
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • bulkchart32
                i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                by bulkchart32
                i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                06-19-2025, 02:37 AM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
