(SOLVED) Sharp LC-46SB57UN Takes a couple to turn on and then no video.
+ More Options
Posts
  • JDC
    • May 2015
    • 273
    Solution: Replace main board. I didn't in this case and ended up scrapping the TV.
    This particular set is known for losing its 5V standby. There are repair kits available for this issue and a couple threads addressing that issue here in the forums. This particular issue addresses the TV taking a few tries to turn on and when it did, there was no video, and nothing lit up. I'm assuming the main board wasn't sending the signal to turn the backlights on. Power switch was tested and confirmed working.
    A replacement main board on ebay is around $200, not worth it in my opinion.
  • JDC
    (SOLVED) Sharp LC-65N7000U - Dim display
    by JDC
    Sharp LC-65N7000U TV
    Issue: Dim display
    Solution: Replace backlights. Possible panel issue?
    When the TV is turned on, it shows a good picture but the brightness looks to be about a quarter to half brightness despite turning the brightness to 100. Upon factory reset, backlights began fluctuating. This indicates either backlight issues (likely) or a problem with the panel itself.
    08-12-2024, 08:44 AM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • SONY_E-WASTER
    Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
    by SONY_E-WASTER
    Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
    The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
    then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
    does...
    12-26-2021, 05:46 PM
  • gavenb
    Sharp LC-80LE661U 80 inch
    by gavenb
    Hi folks!
    I have a LC-80LE661U that had some interesting issues.
    Initially, it would come on and show the sharp logo and would show normal static before shutting off.
    I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
    11-12-2023, 02:05 PM
