Zenith HDV420 Won't Come Out of Standby
  • gfgray
    • Jul 2009
    • 15
    If you have a Zenith HDV 420 HD STB and all you have is the red standby light which will not turn green, this is the workaround. Jumper the red wire going between the power board and the main board to the gray wire right next to it.
    The limitation of this fix is that if you ever hit the power button, you will have to pull the plug and plug it back in before it will give you the green light again.
  • aliasdck
    • Sep 2009
    • 100
    Re: Zenith HDV420 Won't Come Out of Standby
    I am curious what the red and gray wires you have jumped together are labelled as on the powerboard. I can't make it out from the picture. I don't want to jump to any conclusions without understanding why this "fixes" the problem but it may not be such a good idea to override any safety features that have been designed into this tv.
    • gfgray
      • Jul 2009
      • 15
      It is actually a set top box to be used with HDTVs that don't have an HD tuner built in. This workaround is just tying 5V or whatever into the "wakeup" wire. I don't recall what exactly they are labled. I think it has more to do with energy saving than with safety. I think this prevents the power supply from going into energy saving mode and shutting down certain power circuits.
      • Wizard
        • Mar 2008
        • 2296
        Are you certain this power supply and mainboard had capacitors replaced before trying this trick?
        Cheers, Wizard
        • NxB
          • Feb 2009
          • 1595
          You're forcing the backlight on, this could end badly.
          • gfgray
            • Jul 2009
            • 15
            No capacitors were replaced on the power board. I was going to start guessing as to which caps needed to be replaced. But then I tried this. I posted in case someone else on the internet has the same problem.
            NxB, please note that a set top box tuner does not have a screen and therefore does not have a backlight. Am I the only person that knows what a set top box is? lol Anyway it has been humming along nicely for like 4 months - except when someone hits the power button.
            Edit - I think I measured only a few mA flowing through my jumper in case anyone is concerned that something is seriously shorted out.
            • aliasdck
              • Sep 2009
              • 100
              I over looked the fact that you were talking about a set top box and assumed you were talking about a tv.
              • NxB
                • Feb 2009
                • 1595
                same here.
                • gfgray
                  • Jul 2009
                  • 15
                  np, hopefully all the free bumps will make it easier to find for the next person who has this problem
                  • Scotcho
                    • Sep 2011
                    This worked perfectly for me. My HDV420 won't turn on either and replacement boxes are expensive. I used a small resistor that I had around the house to make the jumper. Picture attached.
                    • gfgray
                      • Jul 2009
                      • 15
                      Thanks for the feedback Scotcho. You are smarter than me to use a current limiting resistor for safety instead of a jumper.
                      As an update, this trick eventually stopped working on my box after many months. I tried replacing several of the large SMT caps on the mainboard, but it did not help. So I ended up tossing mine. Too bad, because I could have loaned you my power supply board to see if the problem is with it or with the main board. When yours finally dies, hang on to it until someone else replies to this thread.
                      Gordon
                      • Scotcho
                        • Sep 2011
                        Well, I went to use my set top box for the playoff games yesterday and no lights. It's given up the ghost. I'll keep it around for a while on the shelf to see if any other suggestions to revive it are posted.
                        • Yellowstone22
                          • Nov 2012
                          I tried this and it worked Great. Thanks for taking the time to post this fix
                          • gfgray
                            • Jul 2009
                            • 15
                            If you and Scotcho are willing, the next step is for Scotcho to send at least his PSU and maybe also his motherboard to you before your unit fails completely. Then, you can swap parts out and see if the issue follows the PSU or motherboard.
                            Gordon
                            • escheids
                              • Dec 2013
                              • usa
                              I know this is an old thread, but I have(had) the same problem. I didn't like the idea of jumping across the wires but I tried it and it worked. The new news is that I removed the jumper when it powered on and it stayed on, and I was able to off/standby/on again without the jumper several times. I don't know how long this will last, but maybe someone with more electronic experience can debug with this new info.
                              • gfgray
                                • Jul 2009
                                • 15
                                That info doesn't give me any more ideas. It will probably stop working if you unplug it. I would recommend that you ask scotcho to send you his power supply board (or you can send him yours) to see if the problem is with it or with the main board. Then whichever one of you can, start testing at the component level.
                                • ColoradoSky
                                  • Aug 2017
                                  Thank you gfgray and Scotcho! This worked for me. Thanks for the pictures, they really helped.
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • wnlewis
                                    New wire for my RDE3340 Whirlpool electric range
                                    by wnlewis
                                    OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                    This is a Whirlpool RDE3340 electric range.
                                    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                    Where may I find parts...
                                    01-08-2025, 11:21 PM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
                                  • mikey5791
                                    Tiny Tech ATX480W output power ticking
                                    by mikey5791
                                    Hi to all forum members,
                                    ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                                    Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                                    02-20-2025, 01:11 AM
                                  • emeskay
                                    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                    by emeskay
                                    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                    08-06-2024, 07:13 AM
