I got ahold of a bunch of these sets. Some have cracked screens, and the others were lightning strike victims. Simple enough to swap good mainboards for bad. Tvs power on and display the HDMI input. I can change it to tv, but I had to scan for digital channels. Tvs work just fine until I turn them off. They reboot to the RCA screen and then go to HDMI screen. When I change it to tv they start to autoscan for channels again. I cant find any info, or a manual on these sets. I'm thinking I might need a MASTER remote. Any ideas?
RCA J40BE925 hospitality set
Re: RCA J40BE925 hospitality set
To exit the set from COMMERCIAL mode :
Press menu
Go over to lock symbol and press the down button
Enter 0000 for the password
Set system lock to off
Go down to commercial menu and press ok change to off.
To stop the set from running the setup wizard every time the tv is turned on:
Press menu
Go over to the tv setting on the left
Go down to auto channel scan and set to off.Comment
i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
by The WABBITI had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...-
Channel: BIOS Requests ONLY!
07-12-2021, 04:20 PM -
by sect-sinHi everyone,
I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
My last resort would really be flashing the...-
by Ronald100I need a dump of the xdpe132g5c firmware on the gigabyte x570s aorus master motherboard to burn onto a new virgin chip
by Ronald100Hello everyone, first of all, sorry for the English, but I have a problem like this, so in my case it's a gigabyte x570s aorus master with the blessed xdpe132g5c shorted to 12 volts, I changed a tda and the xdpe, but to work I need a functional firmware, does anyone have a file or board that can extract the firmware?
- Loading...
