Samsung Plasma PS43F4500AW Won't Start (flashing standby)
  • check12
    • Nov 2012
    • 103
    Hi ... Samsung Plasma PS43F4500AW ... when powered with 240V mains standby flashes, pressing PWR button causes standby LED to go out but nothing further happens.
    I have already removed and benched the SMPS, jumpered PS_ON to GND, VS_ON to 5.3v and have VS & VA voltages and all other voltages available at CN4007.
    VS=213v
    VA=58v
    SVT_VS=213v
    This suggests to me that the SMPS is probably ok but I have no experience of TV repair so could do with some help.
    I have removed the XY-Drive board and checked all the ribbon cable connectors for shorts and found none, so I think the Logic+Mainboard is probably the fault but not sure how to proceed from here.
    What further tests can I do to confirm that it is the L+M board?, can I safely turn the screen on to test it? At the moment the SMPS is sitting with all other boards unplugged including the X-buffer (which is part of the SMPS in this model).
    Any help well appreciated ...
  • lotas
    • Jan 2016
    • 4809
    • Russia
    Re: Samsung Plasma PS43F4500AW Won't Start (flashing standby)
    Samsung 43F4500 training
    • check12
      • Nov 2012
      • 103
      Wow! that's Fantastic Lotas! .... Just what I was looking for.
      I searched high & low and couldn't find anything like that ....
      • 7ony
        Samsung plasma - flashing standby light
        by 7ony
        The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
        Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
        Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
        No visible...
        08-31-2020, 05:18 PM
        09-07-2024, 05:50 AM
      • Bloopeta
        Samsung UE43KU6400U Flashing Red Standby Light
        by Bloopeta
        Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
        Power button does nothing
        Have unplugged the mainboard, and backlights illuminate.
        Have tried removing panel ribbon cables one at a time, and that makes no change.
        With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
        Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
        09-11-2023, 02:34 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • fuxxy
        Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
        by fuxxy
        This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
        Plug the set in, and it will turn on and functions with no issues.
        After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
        Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
        08-02-2022, 09:44 AM
