daewoo DP-42SP
+ More Options
Posts
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    daewoo DP-42SP
    Hi there i recently bought this tv from a family member as it was not turning on when opening it up i found 5 burnt smd resistors
    here are some pics
    sorry about pitcher quality ?
    there are 3 at bottom right next to the transformer
    and another 2 next to the fets
    so i bought a brand new board of ebay and replaced it and it still dosent work
    it will only switch on when you put the voltage switch to low when you put in on high you get one click then a few seconds later another
    I am in the process of checking the caps but my solder tips are nackered
    so i cant remove any just now. Any advice and help appreciated
    thanks.
    Your never to old to learn
  • PlainBill
    • Feb 2009
    • 7034
    Re: daewoo DP-42SP
    here are some pics
    thanks.
    Advice, first. Read the FAQs, especially this one on inserting images.
    Next, it would help if we know the area you live in - or more specifically, is your line voltage 120 VAC as in North America, or 240 VAC as used in other parts of the world?
    Also, it's a minor point, but I fail to see the purpose of posting mediocre pictures of a power supply you don't need.
    Question next. Who made the panel in this TV? This should be on labels in the upper right or upper left of the plasma panel. I'd suggest pictures, but....
    Help next: A common cause of the symptoms you describe is a shorted load - for example, a shorted Z-sus card. LG Electronics suggests troubleshooting by unplugging power cables to specific cards to identify the culprit. NO IDEA what would happen if you tried this on panels from other manufacturers.
    More help: Search Scribd. They have a lot of training manuals and service manuals for plasma TVs.
    PlainBill
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Re: daewoo DP-42SP
      hi there very sorry about the upload of the pics from another web i am new to this but i was trying to show the burnt resistors locations but the camera i borrowed wasn't that good at close ups.
      And i live in the uk ( 240v )
      Here is some better pics i have circled the problem area in red
      The power board part number is ( pkg-1971 ) made by Sanken pdc20327.M
      The panel maker not sure. Hear are some pics of the stickers on the pdp
      first sticker
      2nd sticker
      I am in the process of checking the caps with a cap meter on the y-sus as i have read a previous post about one failing they are made by
      ( samwha ) 250v 150uf there are four on this board but my soldering iron tip is not transferring heat the tip is dull. so awaiting new tips.
      Any help appreciated thanks for keeping me wright plainbill i will remove the first two pics . i hope i have done the pics properly this time.
      thanks again.
      • PlainBill
        • Feb 2009
        • 7034
        Re: daewoo DP-42SP
        Maybe Daewoo makes their own plasma panels?
        PlainBill
        • garrymc123
          • Apr 2010
          • 336
          • United Kingdom
          Re: daewoo DP-42SP
          i dont know who made the panel ?
          I have read in previous posts to disconnect xsus and the ysus one at a tome to see if it will stop duble clicking to safe mode tried removing the xsus cable then the ysus cable but Evan if i remove both the cables at the same time the power board still clicks twice does this mean anything.
          thanks.
          • PlainBill
            • Feb 2009
            • 7034
            Re: daewoo DP-42SP
            thanks.
            Probably. Design varies from manufacturer to manufacturer, but the usual process it the standby power supply (typically 5 volts) is on whenever the TV is plugged in. This provides power for the standby processor and the remote control receiver. When the power button is pressed the standby processor closes a relay to turn on the main power supply, then monitors the various main power supply outputs. If any of these supplies do not reach their nominal value within a second or two the main power supply is turned off.
            Most power supplies I've seen in plasma TVs have identifiers on the power supply outputs. By measuring the output voltage of each supply when the power button is pressed you can see which supply is failing, then determine if the problem is the power supply of the load.
            PlainBill
            • garrymc123
              • Apr 2010
              • 336
              • United Kingdom
              Re: daewoo DP-42SP
              Thanks plainbill for that infomation i am going on holiday tonight for a week but when i get back i will check the voltages on the power board at the test points. and i will let you know the results.
              cheers
              garry
                by momaka
                03-12-2025, 03:42 PM
              • flibidy
                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                by flibidy
                I have here a Magnum IA.100 which belongs to my parents.
                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                What Ive done........
                01-01-2025, 01:26 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • howardc64
                Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                by howardc64
                Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                • Backlight on, no image
                • Disconnect right buffer board (view from front), left side display comes on
                • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                • Buffer board is pretty simple
                Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                07-11-2025, 04:04 PM
              • howardc64
                QN75QN85BAFXZA no backlight
                by howardc64
                2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                07-03-2025, 05:08 PM
