50" Mitsubishi Plasma TV
  • aliasdck
    • Sep 2009
    • 100
    Model: PD-5010
    Panel: NEC NP50C2MF01
    The picture on this plamsa is fairly dark and grainy/snowy in appearance. The picture is not stretched fully to the screen on one side. This occurs on all inputs.
    At first I suspected Y or X driver problem but now I don't think so because the osd/menu shows up correctly.
    I am unfamiliar with the video processing circuitry. Any pointers?
    I've found the service manual online but it'll cost about $10 to download... might buy it but I'll look around and see if I can find it for free first.
  • cadiman
    • Mar 2010
    • 397
    Re: 50" Mitsubishi Plasma TV
    correct but dim? driver problem x?
    1)Look on scribd.com for info. I have found alot of info for l/g and panasonic on here free and real training manuals.
    2)Wait for Wizard and Plainbill to respond
    • aliasdck
      • Sep 2009
      • 100
      I was going to take some pictured and post them but I've been called out of town on business. This project will be on hold for a few days.
      Cadiam:
      The display is dim with some static like noise/grainyness. The osd and menu items show up bright and clear so I don't think its a buffer problem.
      • PlainBill
        • Feb 2009
        • 7034
        Cadiam:
        Something to think about: Does it occur on all inputs, or only on one? IIRC, this is a pretty early set; I believe it doesn't have any digital inputs.
        Have fun storming da' castle!
        PlainBill
        • aliasdck
          • Sep 2009
          • 100
          PlainBill
          Can't sleep... hate being away from home.
          The problem occurs on all inputs, and yes all inputs are analogue. Its an early set and probably not worth repairing but this is strictly a hobby for me at this point... I'm in it for the fun of it and for the learning experience.
          • aliasdck
            • Sep 2009
            • 100
            I finally got some more time to play around with this TV today.
            I was wrong in my original description of the problem. The OSD does not always show up correctly. It depends on what else is being displayed on the screen.
            The TV will show a good display whenever the majority of the display is black. For example, my computer screen saver (black background with just the windows logo moving around) shows up perfectly. Colors are rich and vibrant. The OSD/Menu shows up bright and well defined during this time.
            But the more the screen is filled up with bright colors (Especially white) the worse the picture gets. A full white background barely shows up at all. Lots of noise where the white should be and the display is very dark. When I bring up the OSD/Menu it shows up much dimmer than it should be.
            Any idea if this is symptom of a bad panel, problems in signal processing, or panel driver problem?
            • PlainBill
              • Feb 2009
              • 7034
              The first place I would look is the power supply outputs. Also check the waveforms on the sustain cards.
              PlainBill
              • aliasdck
                • Sep 2009
                • 100
                PlainBill
                I have checked the power supply outputs and they are correct and stable (both when the display looks normal and when it is bad).
                I am unable to check waveforms on sustain cards... my scopes bandwidth is only DC to 10Mhz. I want to buy a used 200Mhz scope... maybe this is a good enough excuse to buy one.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Who needs an excuse to buy new test equipment?
                  PlainBill
                  • aliasdck
                    • Sep 2009
                    • 100
                    PlainBill
                    Needed a good enough excuse to give to the wife
                    So I got a new scope and had a look at waveforms today. Not 100% sure what I am looking at here as I am not familar with NEC panels. I found a service manual for this tv but it does not provide any waveforms or service information for the y,x or z boards. It only contains service information for the power supply and logic boards.
                    But I am familiar with what the waveforms on an LG panel look like and I have been using them as a point of comparison.
                    The Y-sustain waveform looks good on this tv as far as I can tell. The x-sustain does not (assuming it should look somewhat like it does on a lg panel). In fact, the waveform seems to distort more and get noisy whenever the image is experiencing display issues.
                    I've replaced hybrid ic's in the past, but I'm not sure I'm going to go that route this time. I might just swap the board this time around.
                    • aliasdck
                      • Sep 2009
                      • 100
                      Hooked up the scope again today and did some more investigating.
                      I must have been doing something wrong last time as both sustain waveforms look good. I had y sustain on channel 1 and z sustain on channel 2 and everything looks appropriate.
                      I'm beginning to suspect the control board. I followed the troubleshooting guide for an LG plasma set and it suggests the control board as well... (this display is NEC).
                      Guess I might buy a control board (logic board) but I'm not 100% sure this is the problem yet.
                      • Wizard
                        • Mar 2008
                        • 2296
                        You are not making any sense on description of fault.
                        Does picture looks like cut off top or bottom or sides (mainboard failing or panel itself especially Z drivers (columns) which are bonded to the panel (usually bottom, high end with 1920 lines sometimes have both top and bottom chips) which renders TV scrap) or compressed (scaler customer setting error)?
                        Cheers, Wizard
                        • aliasdck
                          • Sep 2009
                          • 100
                          I have trouble articulating the symptoms so I must apologize...
                          The tv displays a perfect image whenever the majority of the display is black... for example, when there is a small logo on a black brackground. But when the majority of the display is a bright color then the image becomes noisy and dark. A full white screen is very dark and it appears the display is struggling to illuminate.
                          • mbates14
                            • May 2005
                            • 169
                            basically from the sound of it, it sounds like your display panel is "starving for power" almost the same symptom you get on CRT when HV is low. sounds as if the Z sustain isnt having any output, or the power supply is weak and it cant hold the full current requirement of the display when full white.
                            • Wizard
                              • Mar 2008
                              • 2296
                              Much better description; check capacitors on SMPS and both X and Y boards.
                              May need a little tweak on Va and Vs if it is just sparkles (looks like pixie dust , sometimes red or green, blue is rare.). Panel draws least when on dark, full white is full power consumed.
                              Cheers, Wizard
                              • ArMaaN376
                                Samsung PS51E550 Plasma TV
                                by ArMaaN376
                                I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                Opened TV cover & observed foll
                                a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                How to confirm Y -Buffer board...
                                06-19-2024, 04:05 AM
                              • jm1234
                                Panasonic plasma TX-P42ST50 - 6 blinks
                                by jm1234
                                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                I checked that board for any obvious faults...
                                05-22-2024, 06:59 AM
                              • KYBOSH
                                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                by KYBOSH
                                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                No picture but you hear the TV static (white noise) playing loud and clear.
                                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                But it seems they didn't get too far and just left it.
                                When I first took a look I was amazed at how pristine the inside looked.
                                Its as if the TV had been in a time capsule.
                                Caps looked like they were just pulled off the self.
                                Copper coils had no sign of corrosion on...
                                02-01-2023, 11:10 PM
                              • alltvrepairs
                                Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                by alltvrepairs
                                I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                Any one met this problem in the past?...
                                10-08-2025, 07:34 AM
                              • chazh
                                LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                by chazh
                                This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                09-01-2025, 08:56 PM
